Dreamplex
Pyromon
BH Lover
Dreamplex 2.1.0-beta49
Changelog for 2.1.0-beta49:
- bugfix for FHD/HD handling, params are not correct
- updadte danish language -> thx to victordk
Thx @ DonDavici
  • enigma2-plugin-extensions-dreamplex_2.1.0-beta49_all.zip
Pyromon
BH Lover
Dreamplex 2.1.0-beta50
Changelog for 2.1.0-beta50:
- added debug checkfilelocation to track down error
- bugfix for m1v with movies and shows
  • enigma2-plugin-extensions-dreamplex_2.1.0-beta50_all.ipk
Pyromon
BH Lover
Dreamplex_2.1.0-beta 51
Changelog for 2.1.0-beta51:
- enhanced library refresh for all types of content
Thx @DonDavici
  • enigma2-plugin-extensions-dreamplex_2.1.0-beta51_all.ipk
Pyromon
BH Lover
Dreamplex_2.1.0-beta52
Changelog for 2.1.0-beta52:
- small bugfixes in subtitle handling
- langugage for subtitle renamer is now unlimited in lenght
thx @ DonDavici
  • enigma2-plugin-extensions-dreamplex_2.1.0-beta52_all.ipk
Pyromon
BH Lover
Dreamplex_2.1.0-beta54
Changelog for 2.1.0-beta54: RELEASE CANDIDATE
- FHD skin fixes
- fixed textutils install
- updated some settings informations
thx @ DonDavici
  • enigma2-plugin-extensions-dreamplex_2.1.0-beta54_all.ipk
Pyromon
BH Lover
Dreamplex_2.1.1
Changelog for 2.1.1:
- possible bugfix for live tv bug
Thx @DonDavici
  • enigma2-plugin-extensions-dreamplex_2.1.1_all.zip
Pyromon
BH Lover
Dreamplex 2.1.2
Update: v2.1.2
Changelog for 2.1.2:
- possible bugfix for gs when no ip is present
Thx @ DonDavici
  • enigma2-plugin-extensions-dreamplex_2.1.2_all.ipk.zip
Pyromon
BH Lover
Dreamplex Stable 2.1.3
Changelog for 2.1.3:
- bugfix for livetv resume function (big thx to RoPor)
Thx @ DonDavici
  • enigma2-plugin-extensions-dreamplex_2.1.3_all.ipk.zip
Moderator
Thx @ DonDavici
If you have configurated well dreamplex ( settings --> check updates on startup ( yes ) and update ( stable versions ), don´t need to upload new versions on forum!
The plugin is --> Upgradable
check this:
ScreenShot.png best regards
Duo2NewGuy
Just installed Dreamplex v 2.1.3 on a VU+Duo2 Enigma2 Black Hole Image v 2.1.5
Sorry, but I'm a complete newbie and I will be wrecking forum members head for info!!
Is it possible to adjust the display so that I can see the settings on the top / bottom & right side of the screen, they are barely visible on the tv screen and I cannot make any changes.
I've looked through the support pages here and I have googled this issue but I cant find anything, which isn't nice.
Moderator
Yes you can ---> OSD position setup plugin ---> you can change the size visible of menus according your TV SET.
Duo2NewGuy
Nunigaia, so from the main menu, I go into Black Hole Apps / OSD Settings & then where??
Or am I going into the wrong menu option??
Moderator
osd position setup ( screen shot )
I am at a moment with my duo2 with Open BlackHole 0.1, but think you´ll got a screen similar to this one:
You can adjust the size of your sreen with your remote control unit --> by changing:
left
width
top
height
Matrix10
In Black Hole image (NOT OPEN BLACK Hole)
If you have a problem on your TV,with the position of the skin graphics.
Install / enable UI Position Setup plugin.Adjust position.
Blue>>Blue>>SpeedUP
http://www.vuplus-community.net/board/attachments/20387/
Duo2NewGuy
Blue>>Blue>>SpeedUP
Blue>>Blue>>SpeedUP
Thanks Matrix10 - found one of your posts with further instructions - thanks a mil
OSD and image Position can be adjusted with the plugin UI Position Setup
First install (enable) plugin in BH Speed Up.
(blue button>> Blue >>Black Hole Speed Up)
Duo2NewGuy
Hi,
Is there a "how to tutorial " to configure dreamplex system server - I've entered my media players IP address, port 08080 (not sure if this is correct), & my myplex username & password.
When I choose sync media, this error appears "list index is out of range"???
Tony il Capo
Blue>>Blue>>SpeedUP
Thanks. I was wanting this and somehow I've missed it. Now it's perfect! :)
Moderator
Hi,
Configure dreamplex server ( on your pc ), is quite simple!
So, i think there´s no need a guide!
Upon that install dreamplex enigma2 plugin ---> Is very simple too:
1) First Screen settings:
2) Continuation of settings
3) Go to Server and click Blue key --> to discover server --> Your dreamplex server ( PC Ip ) - Should appear.
Save settings of your discovered SERVER.
Goto Sync Media ---> It will sync all media on your PC and will create a database.
Go back --> You should now take access to your media ( movies on your server (PC)).
Best regards
Duo2NewGuy
Best regards
Thanks again nunigaia, all my movies are on a linux networked media player "Xtreamer", is there a plugin / addon that I can use on the Vu+Duo2 to watch them on it??
