Dreamset problem
Gigantone
I use Dreamset 2.39 to edit my Duo2's settings. Is it possible to edit satellite and transponder lists through this tool? It seems yes, but it does not work properly for me. Selecting a satellite and picking up its transponder list I find Edit, Add, Delete keys, but only Delete seems working correctly. If I attempt to add or edit transponders I receive this message: "NO PROPERTIES", and I'm unable to continue. Any idea? Thank you.
On Edit folder, choose your satellite
If you want to add a transponder go to the main list on left (select the first one) and click on "+" button to add a new objetc, then fill parameters.
Once yo have done that, go above the channel list which of course is empty and click on "+" button to add new objet, and fill the parameters.
But you will go much faster is you simply click on top left of the screen for "New" then " Internet settings" then tick your relevant sat and download ;)
Yes, I saw that! Thank you for your suggestions. Maybe editing or adding transponders could be useful just in case that a single frequency change occurs, but not in common situations. Do you know if updating satellite.xml always needs a total new channel scan?
Yes you need a new scan as the satellites.xml contains only the tranponders list (see in/etc/satellites.xml).
As there is frequently a lot of changes in channels list, I warmly recommand to download new internet settings with dreamset and make new favourite lists.
But of course it there is few changes into a transponder, you can edit the list of channels Inside this transponder.
