Dreamset problem
Gigantone
I use Dreamset from more than 2 years with my Duo2 and I'm very happy, but I have a little issue not able to solve. How can I add/save new transpondeers or new satellites? For example: I need to add new TP. 1-Open my settings 2-Select Edit Settings 3-Select satellite 4-In transponder list right click>Add Transponder 5-Insert all TP parameters (frequency, symbol rate....), then OK. Now I see my new transponder just created in Transponder list, but when I save all my job, it seems that new TP is not written in satellites.xml file. If I close and open Dreamset again, this new TP is lost. The same when I attempt to open xml file manually, this new TP is not there. Why is it not saved? I just updated to last Dreamset version 2.4.8 but no change. Please help. Thanks.
