Driver rtl8187
Bobsilvio
Allora tentando di compilare questi driver, sul caricamento in sif vanno bene, mentre su blackhole danno problemi:
In fase di caricamento..
root@bm750:~# insmod /lib/modules/wlan/ieee80211_crypt-rtl.ko
root@bm750:~# insmod /lib/modules/wlan/ieee80211_crypt_wep-rtl.ko
insmod: can't insert '/lib/modules/wlan/ieee80211_crypt_wep-rtl.ko': unknown symbol in module, or unknown parameter
root@bm750:~# insmod /lib/modules/wlan/ieee80211_crypt_ccmp-rtl.ko
insmod: can't insert '/lib/modules/wlan/ieee80211_crypt_ccmp-rtl.ko': unknown symbol in module, or unknown parameter
root@bm750:~# insmod /lib/modules/wlan/ieee80211_crypt_tkip-rtl.ko
insmod: can't insert '/lib/modules/wlan/ieee80211_crypt_tkip-rtl.ko': unknown symbol in module, or unknown parameter
root@bm750:~# insmod /lib/modules/wlan/ieee80211-rtl.ko
root@bm750:~# insmod /lib/modules/wlan/eeprom_93cx6.ko
root@bm750:~# insmod /lib/modules/wlan/r8187.ko
ecco il dmesg
ieee80211_crypt: registered algorithm 'NULL'
ieee80211_crypt_wep_rtl: Unknown symbol crypto_alloc_tfm
ieee80211_crypt_wep_rtl: Unknown symbol crypto_free_tfm
ieee80211_crypt_ccmp_rtl: Unknown symbol crypto_alloc_tfm
ieee80211_crypt_ccmp_rtl: Unknown symbol crypto_free_tfm
ieee80211_crypt_tkip_rtl: Unknown symbol crypto_alloc_tfm
ieee80211_crypt_tkip_rtl: Unknown symbol crypto_free_tfm
Linux kernel driver for RTL8187 based WLAN cards
Copyright (c) 2004-2005, Andrea Merello
rtl8187: Initializing module
rtl8187: Wireless extensions version 20
rtl8187: Initializing proc filesystem
usbcore: registered new driver rtl8187
credo manchi qualche pacchetto per il kernel
Forse posso dare una dritta, se per favore qualche admin che compila, controlla se nel def config è abilitato questo:
CONFIG_CRYPTO_CRC32C
almeno come modulo da caricare apparte.
Magari abilitate tutti i cripto almeno come moduli.
CONFIG_CRYPTO
CONFIG_CRYPTO_HMAC
CONFIG_CRYPTO_NULL
CONFIG_CRYPTO_MD4
CONFIG_CRYPTO_MD5
CONFIG_CRYPTO_SHA1
CONFIG_CRYPTO_SHA256
CONFIG_CRYPTO_SHA512
CONFIG_CRYPTO_WP512
CONFIG_CRYPTO_TGR192
CONFIG_CRYPTO_DES
CONFIG_CRYPTO_BLOWFISH
CONFIG_CRYPTO_TWOFISH
CONFIG_CRYPTO_SERPENT
CONFIG_CRYPTO_AES
CONFIG_CRYPTO_CAST5
CONFIG_CRYPTO_CAST6
CONFIG_CRYPTO_TEA
CONFIG_CRYPTO_ARC4
CONFIG_CRYPTO_KHAZAD
CONFIG_CRYPTO_ANUBIS
CONFIG_CRYPTO_DEFLATE
CONFIG_CRYPTO_MICHAEL_MIC
CONFIG_CRYPTO_TEST
Ciao amico, anche io ho una usb-wifi con questo chip, alla fine ce l 'hai di lavoro. Saluti, e speriamo che qualche esperto di aiutarti, se non avete ancora raggiunto.
ieee80211_crypt: registered algorithm 'WEP'
ieee80211_crypt: registered algorithm 'TKIP'
ieee80211_crypt: registered algorithm 'CCMP'
Linux kernel driver for RTL8187L based WLAN cards
Copyright (c) 2004-2005, Realtek
rtl8187L: Initializing module
rtl8187L: Wireless extensions version 20
rtl8187L: Initializing proc filesystem
usbcore: registered new driver rtl8187L
usb 2-1: new high speed USB device using brcm-ehci-1 and address 2
usb 2-1: configuration #1 chosen from 1 choice
rtl8187L: Reported EEPROM chip is a 93c46 (1Kbit)
rtl8187L: Card MAC address is 00:1e:2a:ec:5a:20
rtl8187L: Card reports RF frontend Realtek 8225
rtl8187L: WW:**PLEASE** REPORT SUCCESS/INSUCCESS TO Realtek
rtl8187L: This seems a new V2 radio: rtl8225_zebra2
rtl8187L: PAPE from CONFIG2: 0
rtl8187L: EEPROM Customer ID: FF
=====================>rtl8180_proc_init_one
rtl8187L: Driver probe completed
rtl8187L: Now Radio On
root@bm750:~# iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 802.11bg Mode:Managed Access Point: Not-Associated
Bit Rate:11 Mb/s
Retry:on RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=0/100 Signal level=0 dBm Noise level=0 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
root@bm750:~#
il team ha modificato quello che avevo richiesto è ora continuano i test. anche su blackhole
