Driver TDT Usb A850 with BH 1.6.3
pioner20
For an important reason, I have to use in my VU DUO the BH 1.6.3 image but it turns out that there is no way to find the driver USB DVB-t Avermedia Volar Black HD (A850 / af9015) someone I could pass the files to manually install via FTP or some installing ipk, thank you.
Note: If I use a BH 2.0.8 or BH 2.0.9.1 not have problem with the TDT USB, but I need work with BH 1.6.3
I think it's a hard way to be able to use that tuner in BH 1.6.3 just because linux/enigma2/BH is different from Windows and it's not so easy to install a new driver, and moreover it also has to be available for that kernel version: some system modifications/patches might be required to use the new added "firmware" (drivers in linux).
BTW the AF9015 is an old chipset, but probably 1.6.3 is even older and had no yet included support for it.
Check in the /lib subfolders if you have a file with a resembling name.
Thanks for your answer...
I am looking for other option, and it will be yo get a BH 1.6.3 parched image to install.
My /lib/ modules/ 2.6.18-7.3
Your image is OLD and not yet supported like other versions.
I don't know a valid reason to be statically in a very old image: please explain your needs.
