Dropbear (SSH) dying on BH 1.7.1 and 1.7.2
Sharkys
Hi,
on BH 1.7.1 and 1.7.2 SSH connection is "dying" after some time, while Telnet still works. Anyone else is experiencing this ?
It's working fine for few hours, naturally password is setup. Eg. yesterday evening I did full reboot, today morning I tried to connect - SSH gave me login prompt and died, pernamently. The only way to fix is is to logon via telnet and start dropbear again.
Comando: open "root@192.168.0.7" 22
Comando: Pass: *******
Stato: Connected to 192.168.0.7
Errore: Connection closed by server with exitcode 127
I have same problem some times with wireless, but never with wired connection. I can't prove it but I believe the wireless association during ssh connection block it.
Other little bug in info panel, ssh led is always off, but dropbear daemon run.
HTH
I experience same problem BlackHole 1.7.2
-dropbear ssh conections die randomly when inactive...
- only when using wireless adaptor...
