DTS HD Master bitstream
DTS ES supported by SR501E works with Solo2. That's max. what I can try on Solo2. I don't have possibility to check Ultimo.
DTS HD Master is a totally different from DTS ES, and your Onkyo does not support it.
I know it. It's quite old ;). But still works.
Anyway, DTS HD Master should work (at least in downmix to DTS 2.0 or higher - compatibility mode). It's complicated to test it, because there is no sat provider in my zone who transmits DTS HD MA. Only way is to connect USB BlueRay reader or check with sample files. But I don't have MA audio amplifier.
So it's *.m2ts. I have some 7.1 DTS HD MA trailers and I'll try to play them on SOLO2 this evening.
I tested with this hd_dts_living_world_of_audio_lossless.m2ts D/L from web. SOLO2, BH 203, LG M2450D, HDMI, Downmix ON. Audio/Video works.
You have Ultimo, DTS HD MA Onkyo Receiver. Why don't you try to D/L sample file to test yourself?
