Dual DVB-T Tuner USB stick
Nikos1970
Hello,
I am asking you a suggestion about a recommended and supported device that can make me use the possiblility of recording and wathing two different DVB-T channels.
I have seen a Haupauge Nova-T TD but I don't know if it is supported in our great image.
Thanks a lot for your help!
Hello,
Nova-T TD is supported :)
And what about the Conceptronic CTVDIGDUAL? Nova T is much more expensive than I expected.
Regards
V1 or V2 device?
The producer site has two models listed.
Googling a lot I've found some info about CTVDIGDUAL: seems a dual AF9015 device and should work with current drivers but I haven't tested it.
V1 is named CTVDIGUSB2 and it is a single tuner model, while the V2 is CTVDIGDUAL_V2 and it has 2 tuners.
I think I will buy it and will let you know..I would be glad to help you someway, just tell me what I have to do in case of errors (I mean...how can I send you a log or report).
Thanks
Thanks
The first useful report is the output of "dmesg" command with USB device connected and the content of /proc/bus/usb/devices file.
