Duo2 dual tuner setup question
iwols
hi all just a quickie,at the minute i have all my sats set up on the top tuner input,(motorised and working well),but what i am wanting to do is leave all my motorised setup on the top tuner but, say 28e fixed on the bottom tuner,am i right in thinking that i just remove say 28e from my top tuner setup~(not sure how to do this) and just add 28e to the bottom tuner setup and when i open my channel list how does the vu+ know which lnb input to use ,sorry im a newbie at this thanks
Hi, you don't need to remove 28e from top tuner just configure bottom tuner to 28e. Vu automatically will select shortest way ( fixed bottom tuner instead of moving other one). I have same configuration.
