Dual tuner Vu+SoloSE?
paztero1
I see there is a dual tuner sat for exchange vusolose it (remove the factory that well and put it indicated) works well this tuner.
Where to get it and of course nothing because this tuner does not comment, because it would be a great asset to this deco.
Dual DVB-S2 tuner not fit into SoloSE box and there is no compatible driver avaiable for it.
In the address above and since there is a video showing the three types of tuner that you can put to vusolose, and this video is the house + vu.
The one twin tuner tuner would otherwise not be found drivers and my question is habrar someday.
First of all, in the video a third party web site (not Vu+ directly) shows pluggable tuners.
I admint that german is not so clear for me but I've tried personally to plug the Dual DVB-S2 Vu+ tuner in Vu+SoloSE and it's not fit in the slot.
A moderator of this Board has tried (moving some electronic components) to make fittable the Dual DVB-S2 tuner into SoloSE but there is no support in Vu+ driver as expected because Vu+ has not planned to support Dual DVB-S2 into the SoloSE box.
Nothing that we will make you, thank you as the information provided to me on this subject that was not clear.
A greeting and thanks again.
I have just seen the leaked el nuevo vusolose v2 y this other le puede poner that el dual tuner y tambien tiene eso apart from memory but would ahora posible power poner en el Antiguo vusolose ya el dual tuner the en este deco in if podra place ever.
Only English in International section PLEASE!
Dual Tuners can be used into VU+SoloSE v2. Vu+SoloSE (v1) can only accept single tuners.
Not happy with Vu+ at all, They are making now Vu Solo Se V2, it seems to me they only care how to fill there packet, they should have done this to Vu Solo Se, thinking in advance is the main point of every Company, this is Ripoff, i have Vu Solo Se just 8 month old, what should i do??, never mind, i do not think people are stupid and going to buy this!!
Well I am very disappointed with this, I have the vusolose since January and now I see another deco take to solve the problems that have seen deco rather than solve them.
A real shame, I think next purchase will not vu +.:mad::sad::furious:.
If you are unhappy about the company decision what kind of things we can do ?
You can try to sell your SoloSE box (that i love it) and buy the V2 version.
It's my supposition (I WANT TO CLARIFY THAT THE FOLLOWING PHRASE IS MY PERSONAL IDEA) but Vu+ probably has received a lots of complaints about the single tuner limitation of SoloSE and they try to cover this kind of "problem" with a new box that is a power version of original SoloSE.
It's scandalous. Vu+ thanks. The tuner is compatible only with new solose v2.What it cost to do it compatible with solose 1, without make anothet decoder.
Seriusness of vu+ is very pick down.
Buy another brand from now.
From what I can remember the VU+ Solo SE was made as a cheap, single tuner, receiver, if you wanted to buy a dual tuner you could have paid more and bought the VU+ Solo 2 version.
it might be that the motherboard, in the VU+ Solo SE, is not compatible with a dual tuner, so they produced a newer version that is capable of handling the Dual tuner.
There are lots of receivers, that only have one tuner, and work perfectly well, the receiver you bought, the VU+ Solo SE, still works as advertised, and does the job you bought it for.
As mentioned, if you no longer find it acceptable then sell it and buy one with a dual tuner, or the VU+ Duo 2, capable of 4 satellite tuners, or the older VU+ Ultima which is capable of fitting 6 satellite tuners.
If you don't want to buy another VU+ receiver then there are plenty of other options but this time make sure you know the limits, of your new receiver, before buying.
Yes, of course. This is commercial strategy of vu+.
The quality is surely superior, but i don't know becuase the tuner p&p isn't compatible with solose 1.
I will buy only and always vu+, but in this case they wronged the choice
If Vu+ is Serious as Company???????????, should replace all Vu Solo Se with Vu Solo Se V2 with no cost for Customers that bought Vu Solo Se!!!!!!!, otherwise it is going on the Direction of Chinese Companies Operating in Shenzhen, they seems to make every 2-3 months new boxes with some minor changes, this is called no Good Practice of Company, the other solution is All Customers that bought Vu Solo Se to do some Legal Action against Vu+, this is going to be difficult because Customers are in different Countries, and Vu+ will not even think about you and me and so on, if you complain to them!!!!!!
If Vu+ calls the Vu+SoloSE v2 with another name nobody had none to talk... but Vu+ has choosed to reuse the "SoloSE" name with a revision append and all people write a lot about this decision.
Probably this strategy is derived directly to involve users to migrate from 1st generation boxes (Uno, Duo) to new generation boxes and, I suppose, they have applied a strategy about all complaints received for "Single tuner limitation" of SoloSE v1 box.
In any way it has been a big crap and many reports to be drawn from the deco is in various different languages can and often are misleading I bought mine for the video I put up dual tuner then you commented to me that is not vu + (that's the information that is sometimes removed via internet).
I vego plus a premium azbox was a deco that promised much and left us lying to everyone and sometimes think of the computer or some have gone vu +, because what the vusolose is really unfortunate.
I do not play more this issue is what touches me fuck.
If your needs was a dual tuner device, the SoloSE was a wrong choice from start. End of story.
Now you can sell your SoloSEV1 and buy (if you want of course) the V2.
If you want to discuss about Vu+ decisions, write directly to Vu+.
