Duo 2 E2player switch from remote
james81
Although this is idea is from the xbmc wiki, the file is from my box and working
ftp the attached keyboard.xml to /usr/share/xbmc/system/keymaps
Now have an option (crude) when xmbc player opens and can press zero to switch to the E2player
Should work for solo ?
Unfortunately didn't work for me.
Ah really, thats a disappointment, as its well handy.
It must be solo issue but do find that strange though because these xml files are generic config file for xbmc on all platforms.
I just tried it again using the details and file above and it worked. You do need to reboot, but you've probably did that by now!
