Duo 2, how to connect WiFi?
Ruudi
My Duo 2 is now in bedroom where wired internet is not possible. How to connect it into LAN? Which USB stick I have to use? (fw 3.0.9L). All information re this is welcome.
The Duo 2 has a built in WiFi, you don't need a USB stick, you just have to set it up.
Do you mean that you have Black Hole 3.09 loaded?
By the Network setup, where else: there you have both adapters, the LAN one and the wireless one.
Enter, scan your wifi router and enter the password... nothing special in this procedure.
One of the Black Hole versions had the WiFi option in a different menu, from the network menu, you will need to check the menu options. There was also a problem with certain symbols, in a WiFi password.
I use Open Black Hole, and a cable connection, so I can't remember the Black Hole menu, especially in an older version. During the initial installation, you get the option of wireless or wired, so if you decide to flash the latest Black Hole, you should have the option on setup.
