duo 2 tuner problems
patmyhead
just got duo 2 after 4 years happy viewing with vu duo+
this duo2 has 2 twin tuners fitted is the first tuner module tuner A at top & tuner B at the bottom
& is the second module tuner C & D?
i have VTI image running at present
other problems are i get check tuner error config messages
the tuners set to simple /one sat /astra 28e/ but the channels are grayed out (not there) but then i do a re scan which then finds the channels no problem why is this ?
now i find that only 2 tuners are in the search menu the second tuner C&B is not there any more now wheres that gone
this Duo runs very hot the tuners are hot to the touch display on duo says 37 deg c that would cook my chips
You have LNB cable connected to Tuner A ( simple /one sat /astra 28e)
Tuner B,C,and D all loopthrough config?
This is config with only one single SAT LNB (One cable connected)
