duo red light stuck on starting
yummer
BH Lover
Hi guys quick question placed latest duo BH image 2.1.1 onto friends duo it went well... Everything working correctly... He contacted me after he had been watching it a few hours to say it had hung ... Rebooted and hung on starting and red light (is this the red light of death)... I went round reflashed with image all went smoothly programmed erased flash and cycled through the usual... Rebooted and it hung in exactly same place at starting... His box did feel a little warm but did sound like it was firing up but same again.... Any suggestions? Or is it the red light of death and needs the required components as described in hardware section?
I don't think you'd be able to flash the receiver if it were the red light problem, as I think the thread is entitled Dead Duo, or similar.
Have you checked if the VU+ Duo is genuine, and not a clone?
Have you tried loading an earlier image?
What image did it have loaded previously?
Can you please provide more information on how far the flashing process gets, and at what point it stops.
Hi Mick I'm not a Noob at flashing the old vu's mate ;) its genuine box the flashing process completes its after rebooting its sticking on starting... Tried new image fresh again and previous image even tries reflashing boot loader.... I was a bit pressed for time as I'm on graveyard shift tonight just wondering if anyone's got suggestions as to what to look for next time I'm off... I thought the red light thing may have killed it but as I said it flashed correctly various BH images on my faithful USB drive which I've done a million times before... He said it froze as he was watching and then rebooted it... I've told him to try in a couple of hours to make sure it wasn't just a temperature thing and recommended he gave the old girl a bit more breathing space. Just wondering if there was anything to try next
Does it have an internal hard drive fitted? You could try disconnecting that, and any attached devices.
I would also have the user check the Black Hole system Information, on the new image just press Blue, followed by Yellow, to see what the receiver is doing.
I always put blocks, under each corner, to allow airflow underneath, my receivers.
If it is a temperature problem I'd first check the internal fan, but you can also by a cheap fan, designed to fit under a receiver.
My next port of call was to strip it out and put original vu image on and test to see if it is a hardware issue .... I'll have to wait til days off now... As long as its not the red light of death issue .... Just wondering if any one else has experienced this issue before.... I've had a few hangs but its always cleared after a reboot
right this is where i am up to.... i've removed HDD and usb etc ..... reflashed bootloader and latest original vu image and still have the same Starting and red light on front of duo and not much else.... ive managed to telnet to the box and as i've read @angelofsky1980 recommended to someone else in hardware post ive telneted the command dmesg and have the following :
root@bm750:~# dmesg
pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
PCI host bridge to bus 0000:01
pci_bus 0000:01: root bus resource [mem 0x10510000-0x1051ffff]
pci_bus 0000:01: root bus resource [io  0x8400-0x87ff]
pci_bus 0000:01: No busn resource found for root bus, will use [bus 01-ff]
pci 0000:01:00.0: [14e4:8602] type 00 class 0x01010f
PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
pci 0000:01:00.0: reg 24: [mem 0x00000000-0x00000fff]
pci 0000:01:00.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
pci 0000:01:00.0: BAR 5: assigned [mem 0x10510000-0x10510fff]
pci 0000:01:00.0: BAR 6: assigned [mem 0x10511000-0x105117ff pref]
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
NET: Registered protocol family 1
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
msgmni has been set to 270
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
loop: module loaded
sata_brcmstb 0000:01:00.0: version 4.0
__clk_enable: sata [1]
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
sata_brcmstb 0000:01:00.0: setting latency timer to 64
scsi0 : sata_brcmstb
scsi1 : sata_brcmstb
ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:03:f5:40)
bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
__clk_enable: usb [1]
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Key type dns_resolver registered
EBI CS0: setting up NAND flash (primary)
ata1: SATA link down (SStatus 4 SControl 300)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=55042200
Block size=00020000, erase shift=17
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0201 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.1 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan:  mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 found at page 0000ffc0, version 0xFF for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0xFF for chip on CS0
nand_read_bbt: Bad block at 0x009a0000
nand_read_bbt: Bad block at 0x04dc0000
nand_read_bbt: Bad block at 0x06e40000
nand_read_bbt: Bad block at 0x07ac0000
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007600000 : "rootfs"
0x000007600000-0x000007a00000 : "kernel"
0x000007a00000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
PM: CP0 COUNT/COMPARE frequency depends on divisor
UBI: attaching mtd0 to ubi0
ata2: SATA link down (SStatus 4 SControl 300)
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 118 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 941, bad PEBs: 3, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1874470302
UBI: available PEBs: 0, total reserved PEBs: 941, PEBs reserved for bad PEB handling: 17
ALSA device list:
UBI: background thread "ubi_bgt0d" started, PID 47
  No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 48
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"(null)
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 115421184 bytes (110 MiB, 909 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID A58F6F25-3731-4BE3-8483-39616503FFE9, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:10.
devtmpfs: mounted
Freeing unused kernel memory: 292k freed
procmk_init
dvb_bcm7335: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (bm750)
CPU 0 Unable to handle kernel paging request at virtual address 00000004, epc == e082b758, ra == e071f6a8
Oops[#1]:
Cpu 0
$ 0  : 00000000 10008700 e082b758 00000088
$ 4  : 00000000 88471680 00000000 0020b1c0
$ 8  : 00000004 802436ec 00000000 00000000
$12  : 0000c000 fffffffb 00000000 00002711
$16  : 873e4d80 88fed94c e0b90000 e0720000
$20  : 00000000 e0720000 e0b80000 e0b90000
$24  : 00000000 80243600
$28  : 88fec000 88fed8c0 e0b70000 e071f6a8
Hi    : 00000000
Lo    : 00000000
epc  : e082b758 NEXUS_I2c_GetRegHandle+0x0/0x30 [dvb_bcm7335]
    Tainted: P          O
ra    : e071f6a8 NEXUS_Tuner_Open3440_impl+0x78/0x338 [dvb_bcm7335]
Status: 10008703        KERNEL EXL IE
Cause : 00800008
BadVA : 00000004
PrId  : 0002a044 (Brcm4380)
Modules linked in: dvb_bcm7335(PO+) procmk(O)
Process modprobe (pid: 68, threadinfo=88fec000, task=88dba0f8, tls=77f06490)
Stack : e0755248 e07561ec 88471600 e07432a8 00000002 8004e340 e0b90000 e0720000
          00000003 e0b96cdc e0b90000 e0720000 e0720000 e071f048 e0b96684 e073dd98
          873d9180 00000026 88fed94c 88fed934 00000003 e0715160 e0b90000 e0712f68
          00006000 00000000 88fe5e80 e07494dc 873da400 00000001 00000000 00000000
          00000000 00010001 01000101 00000000 00000064 000186a0 e0b90001 00000000
Call Trace:
[<e082b758>] NEXUS_I2c_GetRegHandle+0x0/0x30 [dvb_bcm7335]
[<e071f6a8>] NEXUS_Tuner_Open3440_impl+0x78/0x338 [dvb_bcm7335]
[<e071f048>] NEXUS_Tuner_Open3440+0x28/0x48 [dvb_bcm7335]
[<e0715160>] NEXUS_Platform_InitFrontend+0x220/0x50c [dvb_bcm7335]
[<e07126c4>] NEXUS_Platform_Init+0x6c4/0x76c [dvb_bcm7335]
[<e0c1c108>] init_module+0x108/0x85c [dvb_bcm7335]
[<80001588>] do_one_initcall+0x160/0x1e8
[<80073030>] load_module+0x192c/0x2120
[<800738d8>] sys_init_module+0xb4/0xec
[<8000e13c>] stack_done+0x20/0x40
Code: 8fb00014  03e00008  27bd0030 <8c830004> 10a30008  24820064  50a00006  24820008  3c02e0b9
---[ end trace 99ad459d5f77abf7 ]---
brcmfb: gave up waiting for init of module dvb_bcm7335.
brcmfb: Unknown symbol bcm7335_fb_sync (err -16)
brcmfb: Unknown symbol bcm7335_fb_fillrect (err -16)
brcmfb: Unknown symbol bcm7335_fb_ioctl (err -16)
brcmfb: Unknown symbol bcm7335_fb_copyarea (err -16)
brcmfb: Unknown symbol bcm7335_fb_start (err -16)
brcmfb: Unknown symbol bcm7335_fb_pan_display (err -16)
brcmfb: Unknown symbol bcm7335_fb_imageblit (err -16)
brcmfb: Unknown symbol bcm7335_fb_blank (err -16)
brcmfb: Unknown symbol bcm7335_fb_cursor (err -16)
brcmfb: Unknown symbol bcm7335_fb_check_var (err -16)
udevd (102): /proc/102/oom_adj is deprecated, please use /proc/102/oom_score_adj instead.
bcmemac: eth0 NIC Link is Down
bcmemac: eth0 NIC Link is Up 100 Mbps Full Duplex
NET: Registered protocol family 10
just wondering if anyone can decipher my issue please?
Can you please expand on starting? Does it say VU+, starting GUI, or can you just hear the fans ans see the red light?
Is this after the image has completely loaded?
In your earlier posts I think you had it running, for some hours, then it shut off, did this happen again or did it just not work?
It hangs on red light with the word "starting" on display... This is now with everything removed ...no HDD no USB no Ethernet cable.... No fan running.... Freshly flashed with latest boot loader latest vu plus image... Same as described so im taking its not software its gotta be a hardware issue that's why I've uploaded the result above as described in another post in the hardware section.
Have you tried pressing the menu button?
Does it hang after the image flashing process has completed, and it re-boots?
Have you tried disconnecting the coax F Connector, just in case this is the problem?
root@bm750:~# dmesg
FS-Cache: Loaded
loop: module loaded
ALSA device list:
UBIFS: parse sync
devtmpfs: mounted
procmk_init
Oops[#1]:
Cpu 0
Hi    : 00000000
Lo    : 00000000
    Tainted: P          O
Cause : 00800008
BadVA : 00000004
Call Trace:
Seems there is a problem during boot up of your box and the box has problems during load of Vu+ drivers.
Try a BH 2.1.0 image to verify if all works properly. This is needed because kernel versions are older in the 2.1.0 image.
I shall try version 2.1.0 again buddy shall I post results again if telnet is available? @Mick12334 what will pressing menu button achieve m8? I have no output to my TV source through HDMI as its not booting up? Would it be advisable to try connecting it up via scart? All connections are removed except HDMI ATM
Sorry, when you said it stopped during the start up screen, I thought you meant the television GUI screen, which has happened to me, but obviously yours isn't even getting to this point.
I also thought the receiver was working, normally, early on, but shut down, after a few hours, which could indicate over-heating, or intermittent hardware problem, due to a failing part.
I am still a little confused as to how far the receiver is getting through the booting up process.
Well if you first switch on your duo of the toggle switch on back you will see the word starting on the front of the duo with a little red light bud like normal.... Then nothing ... It just stops on that stage.... I'll go with @angelofsky1980 advice as he's the guru :) ... I've flashed many a vu including duo, solo2 and duo2 and never come across this before. :lamo: ... I'll post my results later with BH 2.1.0 thanks for replies guys
@angelofsky1980 hi mate as requested i reflashed bh 2.1.0 image to the duo and again same place its frozen... i can still manage to telnet to the box as before..... here is the following readout of dmesg command after reflash
BlackHole 2.1.0 bm750
bm750 login: root
root@bm750:~# dmesg
Linux version 3.1.1 (amedeo@meohome) (gcc version 4.6.4 20120303 (prerelease) (G        CC) ) #1 SMP Wed May 7 21:56:49 CEST 2014
Fetching vars from bootloader... found 11 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n8')
bootconsole [uart0] enabled
Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 pci=1 smp=1 moca=0 usb=1
Using 256 MB + 128 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 0002a044 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
bmem: adding 137 MB LINUX region at 6 MB (0x08949000@0x006b7000)
bmem: adding 112 MB RESERVED region at 144 MB (0x07000000@0x09000000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  Normal  0x00000000 -> 0x00010000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00010000
On node 0 totalpages: 65536
free_area_init_node: node 0, pgdat 8065e340, node_mem_map 81000000
  Normal zone: 512 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 65024 pages, LIFO batch:15
PERCPU: Embedded 7 pages/cpu @81203000 s4384 r8192 d16096 u32768
pcpu-alloc: s4384 r8192 d16096 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: bmem=112M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw ro        otflags=sync
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
Memory: 138256k/262144k available (5381k kernel code, 123888k reserved, 1141k da        ta, 236k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:128
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 405 MHz (202.500 MHz counter)
Calibrating delay loop... 403.45 BogoMIPS (lpj=201728)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
NET: Registered protocol family 16
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
pci 0000:01:00.0: [14e4:8602] type 0 class 0x000101
pci 0000:01:00.0: BAR 5: set to [mem 0x10510000-0x10510fff] (PCI address [0x1051        0000-0x10510fff])
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 128 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
PCI: CLS 0 bytes, default 32
Registering unionfs 2.5.11 (for 3.1.10)
NTFS driver 2.1.30 [Flags: R/W].
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
loop: module loaded
brcm-pm: enabling sata clocks
PCI: Setting latency timer of device 0000:01:00.0 to 64
brcm-pm: enabling usb clocks
Success! Registering the characther device  success with 0
blackhole initialised
ALSA device list:
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
UBI: physical eraseblock size:  131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: data offset:                4096
UBI: max. sequence number:      92
UBI: attached mtd0 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            118 MiB
UBI: number of good PEBs:        941
UBI: number of bad PEBs:        3
UBI: number of corrupted PEBs:  0
UBI: max. allowed volumes:      128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:    1
UBI: total number of reserved PEBs: 941
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: image sequence number:  1779026233
UBI: background thread "ubi_bgt0d" started, PID 45
UBIFS: parse sync
UBIFS: file system size:  116436992 bytes (113708 KiB, 111 MiB, 917 LEBs)
UBIFS: journal size:      9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: default compressor: lzo
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 236k freed
procmk_init
CPU 0 Unable to handle kernel paging request at virtual address 00000004, epc ==        c08eda80, ra == c07d8d04
Oops[#1]:
Cpu 0
$ 0  : 00000000 10008700 c08eda80 c0c60000
$ 4  : 00000000 8769f280 00000000 00000000
$ 8  : 00000004 802db8cc 00000000 00000000
$12  : 80000000 00000000 885bc000 00002711
$16  : 8859ee80 884b39a4 00000000 00000001
$20  : 884b39ac 00000002 00000005 c07d7f50
$24  : 00000000 802db7e0
$28  : 884b2000 884b3930 c07d7fa0 c07d8d04
Hi    : 00000000
Lo    : 00000000
epc  : c08eda80 NEXUS_I2c_GetRegHandle+0x0/0x30 [dvb_bcm7335]
    Tainted: P
ra    : c07d8d04 NEXUS_Tuner_Open3440_impl+0x74/0x340 [dvb_bcm7335]
Cause : 00800008
BadVA : 00000004
Modules linked in: dvb_bcm7335(P+) procmk
Process modprobe (pid: 77, threadinfo=884b2000, task=884cae20, tls=770a9490)
Stack : c080f990 c0810984 00000000 c07fd0c0 00000002 c0c5b6dc 00000003 00000001
        884b39a4 c0c5b6e0 00000003 00000001 884b39ac c07d7364 884b3a84 800bbc90
        88595480 00000026 884b39a4 884b39bc 884b39a4 c07ce0a8 884b39ec 88595e00
        c0c65940 884b39f8 88597e80 00000000 00000003 00000000 00000064 000186a0
        88590001 00000000 00000000 00000001 01000100 00000100 000000bc 00000001
Call Trace:
[<c08eda80>] NEXUS_I2c_GetRegHandle+0x0/0x30 [dvb_bcm7335]
[<c07d8d04>] NEXUS_Tuner_Open3440_impl+0x74/0x340 [dvb_bcm7335]
[<c07d7364>] NEXUS_Tuner_Open3440+0x28/0x48 [dvb_bcm7335]
[<c07ce0a8>] NEXUS_Platform_InitFrontend+0x23c/0x584 [dvb_bcm7335]
[<c07cb49c>] NEXUS_Platform_Init+0x710/0x7c4 [dvb_bcm7335]
[<c0cea0d8>] bcm7335_init+0xd8/0x864 [dvb_bcm7335]
[<80001570>] do_one_initcall+0x160/0x1f0
[<80072e2c>] sys_init_module+0x1040/0x1e48
[<8000e3fc>] stack_done+0x20/0x40
Code: 24020008  03e00008  24020008 <8c830004> 10a30008  24820064  50a00006  2482        0008  3c02c0c6
---[ end trace efd4bef786b2106e ]---
udevd (110): /proc/110/oom_adj is deprecated, please use /proc/110/oom_score_adj        instead.
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
eth0: no IPv6 routers present
root@bm750:~#
bm750 login: root
root@bm750:~# dmesg
Zone PFN ranges:
NR_IRQS:128
Brought up 2 CPUs
TCP reno registered
loop: module loaded
ALSA device list:
UBIFS: parse sync
procmk_init
Oops[#1]:
Cpu 0
Hi    : 00000000
Lo    : 00000000
    Tainted: P
Cause : 00800008
BadVA : 00000004
Call Trace:
root@bm750:~#
Try with an old official image (released on the same period of BH 2.1.0) but I think there is an hardware problem and there is nothing to do.
Is there anyway to identity what could possibly be wrong my friend? I've opened the old girl up when removing the hard drive and can't really find anything toasted? I think it may have to be sent away then ... I'll try last resort of official image around BH 2.1.0 as suggested.... I was thinking it was hardware related and some things popped on the board somewhere but I have no testing equipment and limited electronics experience so prob best left to the experts.:) thanks for reply
Please keep us updated.
I think you need to return the receiver, unless you have a friend with a circuit board tester.
It will probably be replaced and the receiver returned for some new parts.
