DUO restarts while searching for channels
ricko
My Duo restarts and shows starting in the display after 10 seconds when I start to search for channels.
In the beginning ther was "the red light" problem. Replaced C807 and that problem was solved.
But it ended up in this instead.
Is there anyone who recognise my problem and have solved it?
usually RAM memory insufficiency always encountered in Vu+ Duo ,thus causes crashes!
Check the RAM memory!
and post a crash log , if possible!
Sadly no crashlog is generated when my box goes "dead" and restarts again.
RAM looks ok, 35% used
