Duo2 BlackHole 3.0.8 VFD display problem
Hy can someone help whit configuration VFD display
i have problem whit this
Can anybody tell how to set up VFD display
i have DUO2 whit blackhole 3.0.8
The VFD Display is configured by default on image!
In any case if you want and know how to make modifications, you can do it by editing the "skin_user.xml" located at /etc/enigma2 , with for example notepad++ .
Here you have the original BlackHole "skin_user.xml" file needed to VFD Display work properly.
Unzip the attached file to your PC, and by FTP ... using an FTP tool ( Filezilla, DCC, WinsCP etc .. ), send it to:
/etc/enigma2
Restart your STB, then!
