Duo2 Duo2 dead. Need Power supply board
meseriashu
Hi,
My duo2 came with an error on screen and I rebooted. Then it was hanging in the boot loading for a while. I wanted to ref lash it, switch it off/on from the back and it didn’t start anymore. I just hear a sound “PAC!” from inside every 2 sec. I think it is the PSU. Where can I buy a power supply board from? Any advise? I google it but I can hardly find one. Thanks in advance for your help!
Hi,
You can check some reseller here: https://www.vuplus-community.net/board/forums/where-i-bought-my-vu-retailers-list.13/
90% of the times, a good electronic technician is able to fix these things. Also capacitors must be checked. It happened to me as well.
Thank you! I found one from hmsat in Germany. 55 Euros with shipping costs. I changed it and indeed I observed that the old one has a couple of capacitors blowed up. I will replace them and keep it as a spare one. Thanks again for your help!
55€ for what, exactly? a capacitor??? I hope not.
I replaced 2 capacitors for 3€ buying them from the closest electronic shop... Capacitor are the most common parts in electronics.
