Duo2 flashing problem.
manutd4life
I reflashed my duo2 no problem last night. im trying to put a different version of BH on as the other was stuck on the boot up screen. Now when im trying to flash, its says flashing for 2 seconds then it just says checking usb. Anyone come across this before? i cant currently use the box.
Thanks
this is the only one that works or worked. just used it to update the CFE with the same USB and that worked fine. Dunno if the CFE is an old one or if there is a newer one.
Follow all the advices that you can find here: HowTo flash/update Vu+ images
PS: thread moved.
Thats what ive been following, it worked last night but now its not. The current image wont even load, its stuck on the BH image when i boot the box. I did try and update the img via the box after i installed it, thats when the problems started but i just reflashed it and it was fine. Came to use the box today and it wont work. Also tried various img's with no luck. It starts to flash and before the numbers come on (1-100) it jumps to checking USB
I turned the box of for half an hour and tried again, it worked. hopefully once settings are restored, it will be fine again.
iv followed all steps above and tried various images .. using the same usb pen.. iv a vu duo box.
and its still stuck on starting....
im at my wits end...
can anyone tell me which image is suited best and which will work on my machine...
thanks
thanks
Have you tried a full format of your USB pendrive ?
Which version of the VU+ receiver do you have?
In your first post you state you have a VU+ Duo, yet this is a thread about the VU+ Duo 2, two completely different receivers, requiring different images.
