Duo2 going to standby randomly
Hi,
It happened already twice today that the receiver went to standby.
I was alone in the room without touching any electronic device.
Autoshutdown disabled.
The second time i am pretty sure it happened around 30 minutes after turning on.
Any idea where to look to troubleshoot?
Go to menu-plugins-auto shutdown setup and set the following to this -
Enable auto shutdown - disable
Enable action after inactivity - disable
Disable shutdown in EPGRefresh time span - yes
Show in extensions - yes
Hope this helps
