Duo2 hangs after splash screen
Outremer99
The log looks like this - anyone who has an idea what to do ?
Total flash: 512MB
RTS VERSION: 20120919184252_7425_single_encode
ETH0_PHY: RGMII
ETH0_MDIO_MODE: 1
ETH0_SPEED: 1000
ETH0_PHYADDR: probe
SCB CLOCK = 277MHz
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Root Hub
CFE initialized.
USB: New device connected to bus 3 hub 1 port 1
USB: Resetting device on bus 3 hub 1 port 1
USB: Locating Class FF Vendor 148F Product 5372: Driver not found.
waiting for usb...done
checking usb
No Priority Usb
checking front key
Checking usbdisk0:/vuplus/duo2/ignore.update......NO
Checking usbdisk0:/vuplus/duo2/force.update......NO
Checking usbdisk0:/vuplus/duo2/cfe_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/root_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/splash_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/kernel_cfe_auto.bin......NO
Starting splash screen.
Found splash image - Width = 720 Height = 480
Non Interlaced Replace list 043f8100 0c800000Interlaced Replace list 043f86a0 0c
8005a0
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:ubiroot rootflags=sync bm
em=192M@64M bmem=458M@512M memc1=590M
Loading: 0x80001000/7132672 0x806ce600/160720 Entry address is 0x80549cb0
Starting program at 0x80549cb0
Linux version 3.3.8-2.0 (build@buildserver) (gcc version 4.9.1 (GCC) ) #1 SMP Mo
n Sep 1 22:22:57 CEST 2014
Fetching vars from bootloader... found 17 vars.
Options: moca=0 sata=1 pcie=0 usb=1
Using 1024 MB + 1024 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 00025a11 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 30000000 @ 20000000 (usable)
memory: 24e00000 @ 90000000 (usable)
bmem: adding 192 MB RESERVED region at 64 MB (0x0c000000@0x04000000)
bmem: adding 458 MB RESERVED region at 512 MB (0x1ca00000@0x20000000)
Zone PFN ranges:
Normal 0x00000000 -> 0x00050000
HighMem 0x00050000 -> 0x000b4e00
Movable zone start PFN for each node
Early memory PFN ranges
0: 0x00000000 -> 0x00010000
0: 0x00020000 -> 0x00050000
0: 0x00090000 -> 0x000b4e00
PERCPU: Embedded 7 pages/cpu @81e12000 s5632 r8192 d14848 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 407396
Kernel command line: ubiroot rootflags=sync bmem=192M@64M bmem=458M@512M memc1=5
90M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs libata.force=1:1.5Gbps
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Primary instruction cache 32kB, physically tagged, 4-way, linesize 64 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
MIPS secondary cache 256kB, 8-way, linesize 128 bytes.
Memory: 964748k/1048576k available (5499k kernel code, 687988k reserved, 1272k d
ata, 192k init, 604160k highmem)
Hierarchical RCU implementation.
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 1305 MHz (163.128 MHz counter)
Console: colour dummy device 80x25
Calibrating delay loop... 869.37 BogoMIPS (lpj=434688)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
bmem: adding extra 434 MB RESERVED region at 2894 MB (0x1b200000@0xb4e00000)
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
USB1: power enable is active high; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource wktmr
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
highmem bounce pool size: 64 pages
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.30 [Flags: R/W].
msgmni has been set to 704
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
console [ttyS0] enabled, bootconsole disabled 62) is a 16550A
serial8250.0: ttyS1 at MMIO 0x10406b40 (irq = 63) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406b80 (irq = 64) is a 16550A
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mod
e
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: FORCE: PHY spd limit set to 1.5Gbps
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 42
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 42
brcmstb_nand: NAND controller driver is loaded
Found PHY at Address 3
Config GPHY through MDIO
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ata1: SATA link down (SStatus 0 SControl 310)
ehci-brcm ehci-brcm.0: irq 66, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 67, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-brcm ehci-brcm.2: Broadcom STB EHCI
ehci-brcm ehci-brcm.2: new USB bus registered, assigned bus number 3
ehci-brcm ehci-brcm.2: irq 71, io mem 0x10490300
ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-brcm ehci-brcm.3: Broadcom STB EHCI
ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
ehci-brcm ehci-brcm.3: irq 72, io mem 0x10490500
ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 5
ohci-brcm ohci-brcm.0: irq 68, io mem 0x10480400
hub 5-0:1.0: USB hub found
ata2: SATA link down (SStatus 0 SControl 300)
hub 5-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
ohci-brcm ohci-brcm.1: irq 69, io mem 0x10480600
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-brcm ohci-brcm.2: Broadcom STB OHCI
ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
ohci-brcm ohci-brcm.2: irq 73, io mem 0x10490400
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 74, io mem 0x10490600
usb 4-1: new high-speed USB device number 2 using ehci-brcm
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 254
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR LIRC bridge handler initialized
Linux video capture interface: v2.00
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
brcmnand brcmnand.0: 1024MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, H
amming ECC
Bad block table found at page 524224, version 0x01
Bad block table found at page 524160, version 0x01
nand_read_bbt: bad block at 0x00000cfe0000
nand_read_bbt: bad block at 0x00000d020000
nand_read_bbt: bad block at 0x0000165a0000
Creating 4 MTD partitions on "brcmnand.0":
0x000002700000-0x000040000000 : "rootfs"
0x000002700000-0x000040000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000b00000 : "mac"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 4
UBI error: vtbl_check: bad CRC at record 1: 0xe4d3a80d, not 0xf116c36b
UBI error: process_lvol: both volume tables are corrupted
UBI error: ubi_init: cannot attach mtd0
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(8,1)
Please append a correct "root=" boot option; here are the available partitions:
1f00 1008640 mtdblock0 (driver?)
1f01 1008640 mtdblock1 (driver?)
1f02 7168 mtdblock2 (driver?)
1f03 2048 mtdblock3 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(8,1)
Rebooting in 180 seconds..
BCM74250012
M0
M1
01CZL2=1
LLMB=0000C000
BP=02000000
L2Cfg=1E7AD627
L2Buf=77707711
BrCfg=F01C200E
BrMod=02800801
BrZp0=44000000
BrZp1=00002000
CFE ver 2.333.20130710, Endian Mode: Little
Build Date: Mon Jul 15 19:29:18 2013 Vuplus Team
Copyright (C) Broadcom Corporation.
ERROR: MEMC1 reshmoo status = 80000008
CPU speed: 1305MHz
DDR Frequency: 800 MHz
DDR Mode: DDR3
Total memory(MEMC 0): 1024MB
MEMC 0 DDR Width: 32
Total memory(MEMC 1): 1024MB
MEMC 1 DDR Width: 32
Boot Device: NAND
Total flash: 512MB
ETH0_PHY: RGMII
ETH0_MDIO_MODE: 1
ETH0_SPEED: 1000
ETH0_PHYADDR: probe
SCB CLOCK = 277MHz
Initializing USB.
CFE initialized.
checking usb
No Priority Usb
checking front key
8005a0
Zone PFN ranges:
NR_IRQS:160
Detected MIPS clock frequency: 1305 MHz (163.127 MHz counter)
Brought up 2 CPUs
TCP reno registered
loop: module loaded
e
ALSA device list:
amming ECC
Seems there is a problem with mounting the flash into the expected Linux location.
What image are you trying to use?
Have flashed BH 2.1.1 and the problem persists - the only difference is that the splash from BH looks a Little nicer..
M0
M1
01CZL2=1
LLMB=0000C000
BP=02000000
L2Cfg=1E7AD627
L2Buf=77707711
BrCfg=F01C200E
BrMod=02800801
BrZp0=44000000
BrZp1=00002000
CPU speed: 1305MHz
DDR Mode: DDR3
Boot Device: NAND
Total flash: 512MB
ETH0_PHY: RGMII
ETH0_MDIO_MODE: 1
ETH0_SPEED: 1000
ETH0_PHYADDR: probe
SCB CLOCK = 277MHz
Initializing USB.
CFE initialized.
checking usb
No Priority Usb
checking front key
8005a0
Loading: 0x80001000/7846784 0x8077cb80/160080 Entry address is 0x805d6de0
Starting program at 0x805d6de0
Linux version 3.13.5 (buildserver@buildserver) (gcc version 4.6.4 20120303 (prer
elease) (GCC) ) #1 SMP Thu Jul 24 21:30:54 CEST 2014
CPU0 revision is: 00025a11 (Broadcom BMIPS5000)
memory: 31400000 @ 90000000 (usable)
bmem: adding 220 MB RESERVED region at 512 MB (0x0dc00000@0x20000000)
Zone ranges:
Normal [mem 0x00000000-0x4fffffff]
HighMem [mem 0x50000000-0xc13fffff]
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x00000000-0x0fffffff]
node 0: [mem 0x20000000-0x4fffffff]
node 0: [mem 0x90000000-0xc13fffff]
PERCPU: Embedded 7 pages/cpu @82012000 s7040 r8192 d13440 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 461824
Kernel command line: libata.force=1:1.5Gbps bmem=192M@64M bmem=220M@512M memc1=7
88M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
Memory: 1408468K/1855488K available (6022K kernel code, 272K rwdata, 1164K rodat
a, 208K init, 143K bss, 447020K reserved, 806912K highmem)
NR_IRQS:160
Detected MIPS clock frequency: 1305 MHz (163.135 MHz counter)
Calibrating delay loop... 864.25 BogoMIPS (lpj=432128)
CPU1 revision is: 00025a11 (Broadcom BMIPS5000)
Brought up 2 CPUs
bmem: adding extra 236 MB RESERVED region at 3092 MB (0x0ec00000@0xc1400000)
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource wktmr
FS-Cache: Loaded
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
Registering unionfs 2.5.13 (for 3.13.7)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
msgmni has been set to 1174
serial8250.0: ttyS0 at MMIO 0x10406b00 (irq = 62, base_baud = 5062500) is a 1655
bootconsole [early0] disabled
serial8250.0: ttyS1 at MMIO 0x10406b40 (irq = 63, base_baud = 5062500) is a 1655
0A
serial8250.0: ttyS2 at MMIO 0x10406b80 (irq = 64, base_baud = 5062500) is a 1655
0A
loop: module loaded
ahci strict-ahci.0: can't get clock
ahci strict-ahci.0: SSS flag set, parallel bus scan disabled
e
bcmgenet: configuring instance #0 for external RGMII
Success! Registering the characther device success with 0
blackhole initialised
hidraw: raw HID events driver (C) Jiri Kosina
TCP: cubic registered
Key type dns_resolver registered
NAND device: 1024MiB, SLC, page size: 2048, OOB size: 64
amming ECC
random: nonblocking pool is initialized
UBI: scanning is finished
UBI error: vtbl_check: bad CRC at record 13: 0xf116c36b, not 0xf116c36e
Volume table record 13 dump:
reserved_pebs 0
alignment 0
data_pad 0
vol_type 0
upd_marker 0
name_len 0
name NULL
UBI error: vtbl_check: bad CRC at record 27: 0xf116c36b, not 0xf116c36e
Volume table record 27 dump:
reserved_pebs 0
alignment 0
data_pad 0
vol_type 0
upd_marker 0
name_len 0
name NULL
UBI error: ubi_attach_mtd_dev: failed to attach mtd0, error -22
ALSA device list:
UBIFS error (pid 1): ubifs_mount: cannot open "ubi0:rootfs", error -19
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(8,1): error -19
I found also this on another forum
thanks
found thus also for the duo :
RE: Fix bootloaderhi mate, I had the same problem and sent box back to supplier and they came up with this fix. Switch the box off, on the rear side.
choose in putty for serial connect, speed must be set to 115200 and choose you`re comport.
Put the box on, when you`re connection is oke, you wil see some text scrolling over the putty screen.
Now use the ctrl + c key to stop the booting.
copy the following line in the screen:
boot -z -elf flash0.kernel: 'rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3`
The box now reboot from the flash, so watch you`re box.
Then open telnet with dcc and put in the following line.
flash_eraseall /dev/mtd5
and after that the following line
reboot -f
Then you`re box is running again.
It may work for you, nothing beats a try.
If not working ,one good advice : sent it back !!!!!
Manage to run the first command "boot -z ...." and the box reboots, but it never boot all the way. I get the exactly same logg as the one logged earlier in this post. I tried to stop the "second" reboot also with ctrl + c, but you can not run the flash-eraseall from the prompt, since it does not boot all the way... i get the prompt CFE> - any suggestions ?
Send it back to your reseller via warranty.
