Duo2 Duo2 problem hdmi/flashing
war3z
Hello
I get foulty duo2 box normal starting but problem is signal video out black screen and when want flashing from usb get info update press power i try push and nothing happenes i think cpu is foulty maybe who have circuit or hardware and share ?
How long have you had your VU+ Duo 2?
Have you ever updated the bootloader?
Which version flashes across the VU+ diaplay, after switching off, at the rear, and switching back on again?
If your bootloader is the latest try a different USB stick, and downloading the image again.
Are you trying Blackhole 3.0.3 or Open Blackhole 1.0?
Problem is when want flash image power button not work, i check cable and front panel all ok.
Looking diagram duo2.
You are supposed to be reading the CFE information, that is your bootloader details.
When you switch off, your Duo 2, at the rear, and switch it on again, you get a very quick message, on the front display, something like:
VU+ Duo 2 CFE v?
What does you CFE version state?
log:
BCM74250012
M0
M1
01CZL2=1
LLMB=0000C000
BP=02000000
L2Cfg=1E7AD627
L2Buf=77707711
BrCfg=F01C200E
BrMod=02800801
BrZp0=44000000
BrZp1=00002000
CFE ver 2.333.20130710, Endian Mode: Little
Build Date: Mon Jul 15 19:29:18     2013 Vuplus Team
Copyright (C) Broadcom Corporation.
CPU speed:            1305MHz
DDR Frequency:        800 MHz
DDR Mode:             DDR3
Total memory(MEMC 0): 1024MB
MEMC 0 DDR Width:     32
Total memory(MEMC 1): 1024MB
MEMC 1 DDR Width:     32
Boot Device:          NAND
Total flash:
RTS VERSION:          20120919184252_7425_single_encode
ETH0_PHY:             RGMII
ETH0_MDIO_MODE:       1
ETH0_SPEED:           1000
ETH0_PHYADDR:         probe
SCB CLOCK = 277MHz
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Root Hub
CFE initialized.
USB: New device connected to bus 3 hub 1 port 1
USB: Resetting device on bus 3 hub 1 port 1
USB: Locating Class FF Vendor 148F Product 5372: Driver not found.
waiting for usb...done
checking usb
No Priority Usb
checking front key
Checking usbdisk0:/vuplus/duo2/ignore.update......NO
Checking usbdisk0:/vuplus/duo2/force.update......NO
Checking usbdisk0:/vuplus/duo2/cfe_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/root_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/splash_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/kernel_cfe_auto.bin......NO
Starting splash screen.
Found splash image - Width = 720 Height = 480
Non Interlaced Replace list 043f8100 0c800000Interlaced Replace list 043f86a0 0c
8005a0
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:ubiroot rootflags=sync bm
em=192M@64M bmem=458M@512M memc1=590M
Loading: 0x80001000/8547328 0x80827c00/183888 Entry address is 0x8065eae0
Starting program at 0x8065eae0
Linux version 3.13.5 (oe1@build3) (gcc version 5.3.0 (GCC) ) #1 SMP Tue Dec 6 16
:35:41 CET 2016
Fetching vars from bootloader... found
Options: moca=0 sata=1 pcie=0 usb=1
Using 1024 MB + 1024 MB RAM (from CFE)
bootconsole [early0] enabled
CPU0 revision is: 00025a11 (Broadcom BMIPS5000)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 30000000 @ 20000000 (usable)
memory: 31400000 @ 90000000 (usable)
bmem: adding 192 MB RESERVED region at 64 MB (0x0c000000@0x04000000)
bmem: adding 384 MB RESERVED region at 512 MB (0x18000000@0x20000000)
Zone ranges:
  Normal   [mem 0x00000000-0x4fffffff]
  HighMem  [mem 0x50000000-0xc13fffff]
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x00000000-0x0fffffff]
  node   0: [mem 0x20000000-0x4fffffff]
  node   0: [mem 0x90000000-0xc13fffff]
Primary instruction cache 32kB, physically tagged, 4-way, linesize 64 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
MIPS secondary cache 256kB, 8-way, linesize 128 bytes.
PERCPU: Embedded 7 pages/cpu @82012000 s7168 r8192 d13312 u32768
Built 1 zonelists in Zone order, mobility grouping o
Kernel command line: libata.force=1:1.5Gbps bmem=192M@64M bmem=384M@512M memc1=7
88M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1239824K/1855488K available (6561K kernel code, 354K rwdata, 1216K rodat
a, 236K init, 146K bss, 615664K reserved, 806912K highmem)
Hierarchical RCU implementation.
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 1305 MHz (163.126 MHz counter)
Calibrating delay loop... 864.25 BogoMIPS (lpj=432128)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
CPU1 revision is: 00025a11 (Broadcom BMIPS5000)
SMP: CPU1 is r
Brought up 2 CPUs
devtmpfs: initialized
bmem: adding extra 236 MB RESERVED region at 3092 MB (0x0ec00000@0xc1400000)
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
USB1: power enable is active high; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.17
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource wktmr
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
bounce pool size: 64 pages
NFS: Registering the id_re
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
fuse init (API version 7.22)
msgmni has been set to 845
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10406b00 (irq = 62, base_baud = 5062500) is a 1655
console [ttyS0] enabled
bootconsole [early0] disabled
serial8250.0: ttyS1 at MMIO 0x10406b40 (irq = 63, base_baud = 5062500) is a 1655
0A
serial8250.0: ttyS2 at MMIO 0x10406b80 (irq = 64, base_baud = 5062500) is a 1655
0A
loop: module loaded
ahci strict-ahci.0: can't get clock
ahci strict-ahci.0: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mod
e
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: FORCE: PHY spd l
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 42
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 42
brcmstb_nand: NAND controller driver is loaded
Found PHY at Address 3
bcmgenet: configuring instance #0 for external RGMII
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ata1: SATA link down (SStatus 0 SControl 310)
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 66
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 67, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-brcm ehci-brcm.2: Broadcom STB EHCI
ehci-brcm ehci-brcm.2: new USB bus registered, assigned bus number 3
ehci-brcm ehci-brcm.2: irq 71, io mem
ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-brcm ehci-brcm.3: Broadcom STB EHCI
ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
ehci-brcm ehci-brcm.3: irq 72, io mem 0x10490500
ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assi
ohci-brcm ohci-brcm.0: irq 68, io mem 0x10480400
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
ohci-brcm ohci-brcm.1: irq 69, io mem 0x10480600
ata2: SATA link down (SStatus 0 SControl 300)
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-brcm ohci-brcm.2: Broadcom STB OHCI
ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
ohci-brcm ohci-brcm.2: irq 73, io mem 0x10
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 74, io mem 0x10490600
usb 4-1: new high-speed USB device number 2 using ehci-brcm
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
hidraw: raw HID events driver (C) Jiri Kosina
usbhid: USB HID core driver
TCP: cubic registered
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
NAND device: 1024MiB, SLC, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 1024MiB total, 128KiB blocks, 2KiB pages, 16B O
amming ECC
Bad block table found at page 524224, version 0x01
Bad block table found at page 524160, version 0x01
nand_read_bbt: bad block at 0x00000fde0000
Creating 4 MTD partitions on "brcmnand.0":
0x000002700000-0x000040000000 : "rootfs"
0x000002700000-0x000040000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000b00000 : "mac"
UBI: attaching mtd0 to ubi0
random: nonblocking pool is initialized
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 985 MiB) to u
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 7875, bad PEBs: 5, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 179/68, WL threshold: 4096, image sequence number:
739873246
UBI: available PEBs: 0, total reserved PEBs: 7875, PEBs reserved for bad PEB han
dling: 155
UBI: background thread "ubi_bg
ALSA device list:
  No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 56
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/20
48 bytes
UBIFS: FS size: 978350080 bytes (933 MiB, 7705 LEBs), journal size 9023488 bytes
(8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 5258B98F-9459-4952-
EFCBE52, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:12.
devtmpfs: mounted
Freeing unused kernel memory: 236K (807f5000 - 80830000)
INIT: version 2.88 booting
SGI XFS with security attributes, realtime, large block/inode numbers, no debug
enabled
usb 4-1: reset high-speed USB device number 2 using ehci-brcm
ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5392, rev 0223 detected
ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5372 detected
usbcore: registered new interface driver rt2800usb
rtusb init rt2870 --->
usbcore: registered new interface driver rt2870
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1735: No soundcards found...
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
vm.dirty_writeback_centisecs = 300
vm.dirty_background_ratio = 1
vm.min_free_kbytes = 8192
vm.dirty_ratio = 60
vm.swappiness = 30
Starting  vuplus-platform-utilprocmk_init
bcm_event: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (_vuplus_duo2_)
bcm7424: hotplug_callback():
Hotplug - status.connected 0:0:0
[GPIO]Default
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
[MPVR]: >> misc_pvr_init
[VID]: 6bcm7335_video_init
[AUD]: 6bcm7335_audio_init
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
bcm7424: bcm7335_frontend_init(): vtuner1 : 3
BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
BKNI_Malloc(linuxkernel) top users:
    blocks,   bytes, filename:line
      1024,  176128, portinginterface/hsm/src/common/bhsm.c:500
       403,   29016, magnum/commonutils/mrc/src/bmrc_monitor.c:666
  KSEG1 : 0x80000000
lcr 0x3
irq : 63 ret : 0
input: dreambox advanced remote control (native) as /devices/virtual/input/input
0
Resistor Div: 0x1
Duo2 LCD initialized 1
[LCD]: registered
[CI]: registered ci0 249
[CI]: registered ci1 248
[CI]: CI interface initialised
[DFP]: registered dbox fp
[DFP]: Scart 9597 is fo
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0x4
FP Update Driver Loaded
VFDController Update Driver Loaded
BKNI_P_GetTrackAllocEntry_resize: resizing from 8704->14080
      1643,  362452, BSEAV/lib/utils/balloc.c:31
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1  0
[VID]: VIDEO_PLAY 1  2 0
[VID]: VIDEO_CO
[VID]: VIDEO_CLEAR_BUFFER 1  1 0
[VID]: VIDEO_STOP 0  1
[VID]: VIDEO_SELECT_SOURCE 0  0
INIT: Entering runlevel: 3
Configuring network interfaces... NET: Registered protocol family 10
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Starting system message bus: dbus.
Starting Dropbear SSH server: dropbear.
Starting automount: done.
Starting rpcbind daemon...done.
starting 8 nfsd kernel threads: done
starting mountd: done
Mounting remote filesystems...
creating NFS state directory: done
starting statd: done
starting Busybox Periodic Command Scheduler: crond... done.
crond[603]: crond (busybox 1.24.1) started, log level 8
Fuse filesystem already available.
Mounting fuse control filesystem.
Starting internet superserver: inetd.
/usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/dpf1.conf nicht gefunden
/usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/dpf2.conf nicht gefunden
* starting DLNA Server: minidlna... done.
chown: unknown user/group rdnssd:nogroup
Starting IPv6 Recursive DNS Server discovery Daemon rd
Starting Samba: smbd nmbd.
Starting syslogd/klogd: done
Starting telnet server: telnetd.
* starting FTP Server: vsftpd... done.
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
   ...done.
[VID]: VIDEO_CONTINUE 1  1
vm.dirty_ratio = 60
vm.swappiness = 30
PYTHONPATH: /usr/lib/enigma2/python
DVB_API_VERSION 5 DVB_API_VERSION_MINOR 10
framebuffer not available.
executing main
enigma2 is the main pvr application... adjust oom score!
UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -834019856
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[AUD]: AUDIO_SET_MIXER : amixl 3, amixr 3
[AUD]: AUDIO_SET_MIXER : next left volume -284, right volume -284
Box starting but still no video and problem is flashing from usb when get info push power button still not work.
If it's not flashing then try a different USB stick, and port, and hold the power button in until it reads your USB stick.
Are you using HDMI or scart cable, to connect to your television?
