Hello,
I must be completely dumb but I can't get my new Duo2 (dual DVB-S2) configured properly.
I bought it to replace my SimbaHD (which is crap anyway but at least I'm able to watch TV with it). My Dish setup is the following:
Atlantic Bird 3 05.0W Hotbird 13.0E
QuadLNB QuadLNB
| A B |
| Multiswitch(MSP908) |
| 1 2 3 4 5 6 7 8 |
vu+Duo2 top LBN IN port
First, I updated the image to the latest OBH (OpenBlackHole-0.1-vuduo2_usb_nightly_20150619_78a407f.zip)
I set up the Tuner Configuration for tuner A to:
Configuration mode: Simple
Mode: DiSEqC A/B
Port A: 5.0W Eutelsat 5 West A Ku Band (tried automatic but detects nothing)
Port B: 13.0E Eutelsat Hot Bird 13B/13C/13D (tried automatic but detects nothing)
Set Voltage and 22kHz: yes
Send DiSEqC only on satellite change: no
Tuner B is set-up as Loop through to Tuner A
When I do an automatic service scan it detects nothing (0 channels found).
It is not a problem of my antenna since my old receiver still works when I plug the cable to its LNB IN.
I'm out options, do you have any suggestions ?
Thanks
4H
QuadLNB QuadLNB
| A B |
| 1 2 3 4 5 6 7 8 |
Mode: DiSEqC A/B
Thanks
4H
