Duo2 tuner A not working
Boggvald_Kai
I have a Duo2 with a fixed 4 dual LNB dish, with 2 cables each feeding a S2 tuner. Both tuners are configured for all 4 LNBs.
After working fine for 6 months, tuner A is now not working. Tuner B is fine. On Sat Finder in the menu Tuner B locks fine with a strong signal. Tuner A is completely dead, no signal at all.
I've tried to switch the coax cables, but the problem remains same. Therefore I have assumed the problem is not with dish but Duo2 or tuner? I have tried to downgrade OpenVix without effect.
Any suggesions would be most appreciated.
Have you tried clean tuner contacts (
for example, with contact spray or with alcohol)
and then put back in his place
or better , put the first tuner to the place of another and vice versa
to be sure that the problem is in the tuner and not on the motherboard.
I had a same problem before and solved it by cleaning the main-board . To be sure, make a measuring in tuner output if there is normal voltage( 13 or 18) then problem refers to out of box and if no voltage or short circuit , it is hardware issue .
