duo2 tuner setup
the0sorrow
hi
I have 2 antenna setup. On first dish i have triple lnb(13.0 16.0 19.2) one cable out of it connected to disecq. On other antenna i have 2 single lnb's, 1 on 23.5 and 2nd on 28.2, noth connected separately to before mentioned disecq. From disecq i have single cable that leads to mu tuner.
In advanced tuner setup i manage to find 28.2 as lnb5, 23.5 as lnb2 and 16.0 as lnb3 but i cant find how to make 13.0 and 19.2 working.
Hopefuly someone will be able to help me!
thanks
I assume your'e using a triple Monoblock LNB, for 13E, 16E and 19.2E.
Have you had this system working before, or is it new?
You might want to first run a cable, directly from the triple Monoblock to your Duo 2, and see if you can scan in the channels, for 13E, 16E, and 19.2E.
Thanks on reply
yeah triple monoblock like on this picture.
This is new system, i had 2 antennas with 2 single lnb's each. I had 13.0 and 19.2 on first antenna and 23.5 and 28.2 on second antenna, connected to 4/1 diseqc and everything was working fine.
I don't get it why i am able to pick one satellite(16.0) from the triple monoblock lnb but can't configure rest 2
It might be because you're going through a Diseqc switch, the triple monoblock will have its own system.
First please try running a cable, directly, from the triple monoblock LNB, then set the tuner up to simple, Diseqc A,B,C,D, and try selecting 19.2E, on each of them, one at a time, and scanning in a few channels.
If this works try 13E, then 16E.
Yesterday after i installed triple lnb and got back to duo2, tuner was still set on old settings i only had 19.2, and then i started setting up tuner so i can have all satellites. Since then i easily set those 3 that i already mentioned but no luck with 13.0 and 19.2.
The LNB's, on 23.5E, and 28.2E, I assume are individual, so will not cause a problem, it's the triple LNB that seems to be causing the problems.
All you can do is eliminate the possible causes, one at a time, starting with checking if you can receive all 3 satellites, 13E, 16E, and 19.2E, when the Diseqc switch is taken out of the wiring.
Yes they are individual. what i don't get is why am i able to get 16.0 from that triple lnb, and how was i able to pick up 19.2 just after i installed triple lnb while duo2 was on old settings
I will go to switch it off diseqc
