DUO2 tuners
Bogard
After an update, it seems that the tuners are both off: 0% . The antenna and cabling are tested OK with another decoder.
Setting:
Tuner A = Tuner B
config mode: simple
Mode Diseqc A/B
Port A: Astra
Port B: Hot
Voltage & 22 kHz: Yes
Please help.
Which image are you using?
What satellite set up do you have, fixed dish, with multiple LNB's, Motorized dish, with twin/quad LNB?
Tuner A should be setr up to the satellite you're trying to view, depending on your dish set up.
e.g. A fixed dish, with two LNB's, for 13E, and 19.2E, should be Simple, Diseqc A/B, A = 13E, B = 19.2E.
Then once Tuner A is set up, correctly, you can either set Tuner B up independently or Equal to Tuner A.
Please post back with more details, regarding your satellite set up.
Neither Astra 1, 19.2E, nor Hotbird, 13E, have such a frequency listed, and you still haven't providced the information, I requested, regarding your satellite set up.
If that's the only channel missing then it might have changed frequency, or stopped transmitting.
Please provide the necesasary information.
