[quotI302"]You have to use thedidnt Drin Remote code on the Duo2, then accordingly you have to change also the code on the Duo2 remote (otherwise it won't work any longer), following the instructions below.
In your case the code to use is Mode 1 (Solo/Duo)
6. System Code Change.
You can change the system code of your Vu+ universal RCU according to the Vu+ model that you want to control. The default system code is Mode 2.
Mode 1 : SOLO / DUO
Mode 2 : UNO / DUO2
Mode 3 & 4 : reserved for future models.
Press <<2 + 7>>, <HELP>, <0001 or 0002 or 0003 or 0004>
1. Press 2 and 7 for three seconds until LED is on.
2. Press HELP
3. Press <0001 or 0002 or 0003 or 0004>[/quote]
I did already try this but it didnt seem to work, I tried again and its now working, thanks for your help anyway!
