I have two spare LNB channels to support a new DUO2
I want the DUO2 to be able to record as many channels simultaneously and appreciate some limitations re the V&H polarisation. Hence I am buying two twin tuners. (A new Sat dish with more LNB's to follow latter)
I note I have loopthrough configuration capability on each tuner between ch A and CH B but assume I could also split each LNB channel. Currently I cannot easily get extra feeds into the room. Do I configure as below with A=B and C=D. I assume I cannot internaly switch/ map feeds from A-C as they are seperate cards.
Device LNB Tuner
DUO2 ch1 tuner A
DUO2 tuner B
DUO2 ch2 tuner C
DUO2 tuner D
Device LNB Tuner
DUO2 ch1 tuner A
DUO2 tuner B
DUO2 ch2 tuner C
DUO2 tuner D
Update
I have been advised the best strategy is to use two LNB splitters with each SAT cable driving the two i/p's of each tuner card. Obviously I am therefore limited to the same ch and polarisation for each tuner card. There is no loopback o/p capability so this is the best I can achieve until I run another two LNB sat connections into the room.
I have looked at stacker/destackers but they are expensive and therefore I will wait until I install a 2nd Sat dish with an Octal LNB .
Sorry friends I'm not sure about the right section of my post but I have this problem with VU+Duo 2, 1 tuner sat and 1 DDT tuner, Black Hole Galaxy 2.06, but when I record from sat tuners every other sat channel is lost (no tuner free...) the problem is the sat tuner (not... dual....) nim AVL 2108 nim cdx 1978....
Watching a channel while recording another with a single tuner is only achievable on the same transponder assuming your CAM module has multidecrypt capability.
