Duo4k hdmi-in
club06880
Hallo everybody,
I,ve bought the new duo 4K box and installed the BH image, I’ve connected an appletv trough the hdmi in port.
Evrithing works, I have inserted in my channel list and I’m able to record, the only problem is that is not possible to stream or transcode it. There is a way to do that, I’m doing something wrong or isn’t this Feature available for the hdmi in?
Thanks in advance for your reply.
Regards
Massimiliano
The HDMI-IN connection is for connecting another video source, such as an old euroconnector switcher.
Only 720P works and with content protection.
La conexion HDMI-IN es para conectar otra fuente de video, como un viejo conmutador de euroconectores.
Solo funciona 720P y con proteccion de contenido.
PlayTV: HDMI-IN=====\
-----------------------------------> HDMI-OUT
VU+DUO4K========/
From openwebif will work well the 2 channels you have to stream.
Desde openwebif funcionara bien los 2 canales que tiene para hacer streaming.
En español para mi.
The HDMI-IN port is an audio-video port and has nothing to do with streaming.
La porta HDMI-IN è una porta audio-video: non c'entra nulla con lo streaming
