Duo4k kodi sort problem
SadSyd
Hi all, I'm having problem with kodi on my duo4k.
Actually everything works but when I scan my movies (mounted from a NAS via NFS) the movies are correctly indexed but it's impossible to change the viewing order ... It really seems that movies are imported in a fixed order and there is no way to change it (also in the presentation page where usually are being proposed movies in different order i see the exact same order).
The problem it's not present in a duo2 receiver ... may it be related to the duo4k ? Is there anything I can do better investigate the problem ?
Regards
