DVB-C/T problems after update to 1.0.013 DUO2
EML
Hello, I've update OBH from version 1.0.09 to 1.0.013 and now DVB-T doesn't work, always black screen. Also search channels doesn't work . Decoder VU+DUO2 and DVB-T Europe
It is a known issue... You can reflash your image ( using the release available ver 1.0.09 ) , without apply any updates for now. When it´s fixed, we let you know.
On my decoder VU+DUO2 the tuner nim SSH 108 (DVB-T2) work very fine with OBH version 1.0.013 in flash
Hi
I have the same problem with my permutable Tuner (DVB-T2,DVB-C). Black screen after update to OBH 1.0.013. It is difficult to reflash. I have to reconfigure all my setting and my plugins.
Same problem with the latest Open PLI image.
Regards
