Ultimo Dvb C/T tuner, analog ?
stu667
Hello,
I would like to switch to an Ultimo with dvbs2 and dvbc/t tuner but I don't know if the dvbc tuner can handle the analog channels.
According to the specifications it can but I prefer if someone can confirm.
The specs :
Hybrid - DVB-C/T-Tuner:
  • TV and radio programmes with antenna and digital cable
  • VHF-Channel: 2-12 (49...230 MHz) <------ analog stuff here
  • UHF-Channel: 21-69 (470...861 MHz)
  • DVB-C HDTV compatible
  • Input frequency: 51...858 MHz
  • Symbol rate: 1 ... 7 Mbaud/s
  • Input impedanz: 75 Ohm
  • Tuner In/Out connector: IEC
  • DVB-C / DVB-T switchable by software
This would be the ultimate box for me if it works ;)
Hello,
The specs :
I don't know how works DVB-C but this is a digital standard and I suspect that frequencies between 49 an 190Mhz will be converted (or they are already converted) to be only digital.
Well,
I know for a fact that vhf/uhf is analog. I have a few free channels from my cable provider.
In my LG tv (32la620s) I have analog and digital tuner. In the setup there is antenna/cable/satellite.
As you can read in the specs of this tuner in green the purely digital part of this tuner and in red the analog part.
  • Input frequency: 51...858 MHz <------ this is purely digital
Any feedback would be great.
Thanks
Well,
Thanks
I'm pretty sure that the hybrid tuner DVB-T/C it's only digital.
In my country there isn't DVB-C but only DVB-T and I haven't sufficient experience to determine what channels (frequencies) are used by cable providers, I'm sorry for that :(
