DVB EPG - BH 3.0.9 - no popup
hanz2k
Hi,
I just installed BH 3.0.9 and if I go to OpenWebIf - Television - EPG and click on any item, there shoud be pop up window with timer setting, but it wont show up - how can i fix it???
Thx!
Jan
Try and update with this OpenWebif
First with ftp backup the excistin OpenWebif folder in location: /usr/lib/enigma2/python/Plugins/Extensions
Then just unzipp the attached file and with ftp upload the OpenWebif folder to: /usr/lib/enigma2/python/Plugins/Extensions
Overwrite the excisting folder of OpenWebif
Now restart Enigma2 (GUI) and all should work just fine.
