DVB-S2 tuner
ObiWan
Vip
Hi
is it possible to use 2 twin DVB-S2 tuner to have 4 indipendent tuner ?
Are there Limitations ?
thanks
I've not tried it, but Duo2 supports more than 4 tuners, therefore I think there are not problem to use 2 twin DVB-S2 tuners.
http://www.vuplus.com/productDuo2.html :)
Double & Double Tuner
Experience up to 4 tuners with only twin plug-able tuners.
Double & Double tuner in Duo2 indicates twin plug-able tuner system with the availability of using dual tuner. You can experience to have up to 4 tuners with only 2 tuners inserted in DUO2. Moreover, as its tuner system is for DVB-S2 or DVB-T/C, your choice of watching TV will be even more fulfilling.
A pair of Double DVB-S2 tuners is nice, but blindscan will only work on the top two tuners. I wish blindscan would work on all 4 DVB-S2 tuners. EB
wow....
great.. I Was not so sure but now i'm doubtless:)
One of my friend will buy a duo2 with 4 tuners connected with 1)dual feed 2) 3mt motorized 3) 2mt thor/sirius 4) toroidal ...
Not so bad !!!!!
cu
do not confuse with Double & Double Tuner
Experience up to 4 tuners with only twin plug-able tuners ! ! !
this box have only 2x slot on back side and third slot is dead( not in use )
when you use fill both slot with twin double tuners then you need 100% 4 individual input coax cable and this the only way you can record 3x different frequency channels while watching 4TH channels freely.
Now this is some thing every one need to remember !
with only 2x coax cable input you can record 2 channels per input coax cable but they MUST need to be on same frequency.So basically you record 4 channels in total.
