DVB-T for BH 1.7.2: AF9035
thanks for the new driver! i have a question, my tuner, time to time, dvbt crashes, and I have to restart the vu. the picture freezes and begins to be heard one or two seconds of audio before and the image is repeated (2-3 seconds)
hi, I have installed the IPK & I still get 0 services found.
I have bh 1.7.2 on a VU DUO. My usb tuner is an avertv Volar HD.
I go the tuner to work perfectly on windows 7 using the windows media centre.
would you know what is the cause of the issue i am having.
would it help to edit the terrestial .xmb file in the etc folder.
Do you have AverTV Volar Black HD? This is an AF9015 device and should works correctly out-of-the-box but I will make some tests this evening.
yes but ,,,how to install Ipk??????
It's not difficult. Two ways:
1. with BH image: put the IPK into box (via FTP) on /tmp folder and with the Image press Green -> Yellow -> Manual install IPK file
2. with telnet: put the IPK into box (via FTP) on /tmp folder and then launchi this command:
ipkg install /full/path/of/file.ipk
where /full/path/of/file.ipk is the full path of ipk file previously uploaded via FTP.
gracias........
Does this work with 1.7.3?
I´ve tried but get an error.
My Avermedia green doesn´t find any channels at all.
Please, can somebody help me
