SatDreamer
Could you please add a way to enter the regular, 2-digit UHF frequencies (the range is between 21-69 over here) for a manual DVB-T scan, instead of the complicated and impossible to remember MHz numbers? Thanks.
Thanks. Aren't these numbers fixed? I mean yes, they are different for each country/region but still, doesn't a full frequency number always correspond to a specific UHF frequency? I am not talking of course about the "preset" number we use in our TV's or 'favourites' bouquet.
Here are all the numbers. It should be just a matter of selecting the correct region and showing the extra, 2-digit corresponding number, there is nothing to convert/calculate.
