DVB-T tuner channels have no audio
Noddy19
Since i updated to BH 2.1.7 the DVB-T tuner channels have no sound when first changing channels. If I change to a satellite channel and back again the sound returns. I'm using a sony play TV tuner. I didn't have this issue on earlier versions.
Also narration seems to be on automatically for any channels that have it. If i change audio source it goes away but doesn't remember my preference and narration returns when I change back to the same channel again.
Anyone out there that can help or has similar issues?
I have the same problem on BH 2.1.7, if I select a dvb-t channel from the egp or direct number then there is no sound. But if I change up or down to a dvb-t channel then the sound works. Satellite channel are working without problems.
Did you ever find a fix for this problem?
