DVBSKY T330
guli
i wish to know if the DVBSKY T33O usb tuner will work with the vu duo/solo2 . are the necessary drivers available if not is it available .
many thanks .
many thanks .
I've never seen before this device. I don't know if it's supported or not.
Hi
Thanks for your reply , there is a reputable retailer selling this product as a plug & play usb t/c tuner for e2 boxes . He says he has tested it on the vu range with the openatv 4.2 firmware , & it works . The drivers are available from the addons of that particular image .
Hence I was enquiring if it is available for the blackhole image .
Many thanks .
Hi
Many thanks .
I'll investigate
tuner works fine on openatv 4.2. The drivers are on ******* but never managed to get it working in black hole. It often needs rebooting when on a cable channel, makes vu duo freeze.
Panels like the one you use is not welcome here.
Drivers downloaded from third party feeds or websites can hang your box.
