E2 Settings - 13E & 7W
Supermario
Hi Guys
Need your help. Newbie with the VU+duo.
I have just bought a VUplus duo and have installed blackhole in the flash. I am located in the Dubai and I have two satellites 13E Hotbird & 7W Nilesat. Initially, I got first time setting wizard and I did tune the two satellites using SIMPLE setting Diseqc A/B in tuner A. Everything was fine.
Now, I wanted to try the various settings via the Black hole Green Panel through the BH Addons Manager but I could not find both the satellites, so I decided to download the Vhannibal E2 settings Hot Bird 8 March. Now the HB 13E is fine.
Then I went back to service searching - tuner configuration and tried to set up tone B for satellite 7W but I could not do so.
Please can someone assist for to find the First time installation wizard where I can tune in or searching any satellites I want
OR using the Vhannibal E2 Hotbird setting and manually tune to 7W. Or if any one knows of Settings for 13E & 7W).
Any suggestion/assistance will be highly appreciated.
Rgds
Supermario
Hi Guys
Rgds
Supermario
You can install settings for Motor ;)
