EDUP WIRELESS-N USB MINI ADAPTOR
brasco03
EDUP WIRELESS-N USB MINI ADAPTOR EP-N1528 CAN YOU PLEASE BRING OUT FIRMWARE THAT WORKS WITH THIS DONGLE
THANKS
ok no problem I can get you info and its drivers if it helps please pm me your email address and I will send the needed info it runs on Mac OS and also with windows 7 and its a very fast dongle its made by EDUP and max speed is: 300mbps I think
brasco
brasco
Some infos from Windows 7 are sufficient.
Plug your adapter, go to Devices Managment and right-click on your usb dongle.
Go to into Details tab and select "Hardware ID" and post here the strings obtained (you can do copy&paste).
Your dongle is a 300Mbit :D
