Hi:
I had an old firmware fo my Solo2 and today I updated it to the last one.
The problem is that, inside MediaPlayer (my recorded movies from my sat provider), I can not enable the subtitles (the "not allow" symbol appears at the top of the screen). I use it a lot... and at least in this version it does not work.
Another question. Anybody knows how to move with MediaPlayer around the filesystem to play any other videos in my USB hd or network and how to create links to different folders for a quick access (in the other version of BH I had that and I miss it much).
Edit, I forgot. Some time ago, I asked here how to play audio cds (I have a usb DVD recorder connected to the VuPlus). You asked that it will be corrected because was not possible. Is now possible? how?
Thanks for your help... BH is fantastic!
Carlos
Carlos
