Enhanced Movie Center (EMC) V.3.0.0 by Coolman, Betonme & Swiss-MAD
rassi
Anyone tested EMC v3 with BH?
Is there still issues?
Google translated:
feature list
  • Many file types are listed and played with appropriate hardware:
    Video: [,,,,,,,,, "" ts. "" Avi. "" Divx. "" F4v. "" Flv. "" Img. "" Us. "" M2ts "." M4v. ". mkv ",". mov ",". mp4 ",". mpeg "." mpg "." mts ",". vob "]
    Audio: [. "Ac3". "Dts". "Flac". "M4a". "Mp2". "Mp3". "Ogg". "Wav",,,,,,,]
  • EMC has its own player frontend "EMCMediaCenter" with all the formats that your Dreambox, can also be played.
    For the back end of the E2 movie player, the GStreamer plugin, and the DVD player plugin can be used.
    (So ​​must be installed for DVD formats, the DVD player plugin too.)
    (Of course, the "EMCMediaCenter" fully skinned, it will only own converter was used, so that he can be integrated into an existing skin.)
  • The various formats will be marked with corresponding icons.
  • Symlinks are displayed and marked with a special icon. (Not on when the target exists, the symlink will not be displayed.)
    It can be used in EMC's new symlinks are created.
  • EMC can create your own bookmarks
  • The date can be set in the switch on / off. (It is used dd.mm.yyyy)
  • File order can be switched by date or name. In the setup, the sort order can be reversed.
  • For all types of files, there is a status / progress bar. The setup can be adjusted between "progress bar", "% display" or "OFF".
  • Film icon and progress indicator can take four colors: Not Seen [white] alluded, [blue], done seen [green], even during the recording [red]
  • The setup can be adjusted from vieviel percent of the progressbar and the icon will change color.
  • The color of the ProgressBar is possible to disconnect, if you set the setup to 0% and 100%, or will each have only one at the end no color change (eg 5% and 100% or 0% and 90%.)
  • The film status can now be switched in three states [radio button]. Not seen alluded to, saw completion.
    If the state "played" from switch (set to "Not Seen" or "seen Done"), the last position (last Played) converted into a marker.
    Thus appears on the status of "Not Seen" or "Done seen" no query whether more should be continued to the last position. Can while still enjoying the "<" and ">" keys to get the last position as a marker was placed here.
  • On the menu, all markers are removed "Remove all film-markers". This is also useful if you change to the status of the "Last Played" and each one gets everything back markers will be going on.
  • The change of status [radio button] can also be selected with a list of film (more than one movie at a time) to be made (ONLY on status "not viewed" and "Seen Done").
  • For all listed video and audio formats is a "cuts" file created (E2 compliant), as well as making recordings in E2 *. ts one point stopped, continued to "resume" is possible, and markers can be set.
  • NOT even for *. ts files can for example with EITitor a *. meta *. ince or be created in which a description can be deposited.
  • Current recordings are displayed and labeled specifically.
  • With [video / PVR] or [TEXT] key entries can be highlighted. Thus, all selected entries deleted at / move / back in sequence / or status change.
    With the [TEXT] key to start from the position right away everything in between will be highlighted with the cursor.
  • The [Bouquet] keys to scroll to the top or bottom of the list. With the [cursor left / right] side manner.
  • LONG with [video / PVR], all marks are removed.
  • DVD folders (VIDEO_TS VOB), are shown with the directory name and can be played directly without having to navigate to the VIDEO_TS directory need to.
  • "Play All": The [Play] button (old remote with [Shift] - [green] = play) will play all files in current directory starting at the cursor until all have been played.
    If the cursor is on a directory, all files are played in the directory.
    (Even in very large media collection is no delay at startup because the playlist is determined dynamically.
  • With [info long] the title in the IMDb (The Internet Movie Database) to query. (IMDb plugin must be installed for it.)
  • When you can play with EMC in the [green] between pillarbox, panscan, and just scale switch.
    If EMC is finished, put back on the presetting E2.
  • Automatic Trash:
    The Recycle Bin is emptied at the designated time, or at start of E2, if no recording is in progress, pending or within 10 minutes of a recording.
    In operation, the trash is not emptied when a recording is or is present within 10 minutes of recording.
    Could result from upcoming recordings or recordings are not deleted, checked every 30 minutes until no longer being recorded, and no record is present within 10 minutes .... then is deleted.
    Next deletion happens again the next day after the set time.
    Of course, ONLY delete the files that linger even longer in the Recycle Bin as set in the setup.
    This set per day 24 hours residence time required and not simply looked at the date.
    (Because otherwise it could happen so close to midnight what I delete, and delete is set to 01:00 clock recording only a little over 1 hour in the trash was.)
    All this runs independently from EMC in the background, it must be called EMC to not allow the trash is emptied.
  • Setup item "movie list is skinable":
    YES = values ​​from the widget name = "list" are used from the skin.
    NO = default values ​​from the plugin can be used for widget name = "list".
    The potential therefore exists in two different views to switch setup (or the default skin), unless the skin is present.
    (Supporting someone uses another skin of the old version of EMC, can also be placed in the setup to NO.)
  • The E2 timer list can be accessed by pressing the [TV time] out directly from EMC.
  • Currently available languages ​​are: English, German, Dutch, Polish, Slovak, and Italian (thanks to Bschaar, ni_hao, jkkk, Spaeleus and kosmacz for the translation).
Special thanks, of course, concrete mixers, and Olli42 because they have a lot of code written by-nights and programmed!
Even for older versions, is thanks to cmikula and AndyMt
Thanks also to salzrat, zombi, Erim, and for the translations to Bschaar, ni_hao, jkkk, Spaeleus and kosmacz.
Many thanks to all beta testers
Keys from EMC and its function:
Functions in the film list:
- CONTROL CROSS: navigation list in the film (<and> keys scroll entire pages)
- NOSE: Scrolls to the beginning or the end of the list
- Press "<": a directory layer
- Press the ">": back to the previous directory. (Only the last directory is remembered.)
- INFO: Default Enigma2 EPG info (EventView)
- Long INFO: Query titles in the IMDb (The Internet Movie Database). (IMDb plugin must be installed for it.)
- MENU: Function menu EMC (EMC functions) and film plugin menu (eg moviecut plugins such as film, etc.)
- MENU long: Movie menu plugin (plugins like eg moviecut film, etc.)
- AUDIO: Movie menu plugin (plugins like eg moviecut film, etc.)
- RADIO: toggles between seen and unseen alluded
- TV: Load new current directory
- TV time: Gets the timer list of E2. (Eg if virtually a repeat of the timer is active should be stopped, because that is not directly in EMC.)
- VIDEO (PVR): Movie deselect / for multiple selection
(Multiple films simultaneously erase / move / game status change, or play in the selected order).
- VIDEO (PVR) long: Remove all markers
- TEXT: Multiple selection / demarcation of -> UP position (mode is switched back and forth (toggle)).
- OK: Plays from current cursor position / Plays all selected films in order from labeled (playlist)).
- PLAY: (Old Remote Control [Shift] - [green] = play) "Play All" (also accessible via the [MENU] key.)
Plays all files in sequence starting at the cursor down, and begins again at the end of the front.
If  the cursor is on a directory whose contents are played, including all  sub directories in order, and begins again at the end of the front.
- PLAY time: (Old Remote Control [Shift] - [green] = long long play) "Play All Shuffle" (also accessible via the [MENU] key.)
Plays all files from current cursor position with random play off, and begin again at the end of the front. (By the repetition of each file is played only once.)
If  the cursor is on a directory whose contents are played, including all  subdirectories with random play, and starts over again from the end.
- RED: Delete current cursor position / Delete all selected files
(Deletes stands directly in the setup "whereabouts of the files in the Recycle Bin (days)" to 0)
Stop recording when the recording is still active. (Not for repeating timers, then TV long made use of in the E2 timer list to get.)
- GREEN: switching between sorting by alphabet / date
- YELLOW: Move current cursor position (LocationBox opens for destination entry)
(If something is marked can be moved without LocationBox when the cursor is on the target directory.)
- YELLOW long: Copy current cursor position (LocationBox opens for destination entry)
(If something is marked can be copied without LocationBox when the cursor is on the target directory.)
- BLUE: go to "home movie" or play "last film" From (the adjustable setup which function)
- Press "0", "home movie" go after. (Eg practice, if [BLUE] button is configured to "last film".)
- BLUE long: E2 bookmarks with the possibility of new call to set or delete them.
- HELP: List the key assignment
- "4" key: AV Switch -> Switch between pillarbox, panscan, and "just scale".
- Press "7": Direct call CoolTVGuide (Unless CoolTVGuide is installed.)
- Press "8" Direct call of cool single guide (If CoolTVGuide is installed.)
- Press "9": Direct call to cool EasyGuide (Unless CoolTVGuide is installed.)
While playing a recording:
- RADIO: ext. Plugin menu (As with E2 or blue button when BluePanel exisitiert in long blue.)
- DIRECTIONAL PAD UP / DOWN: Call of EMC
- INFO: Show EPG description of the recording.
- TEXT: Teletext show in the recording.
- GREEN: Switching between pillarbox, panscan, and "just scale".
While playing a DVD:
- MENU: DVD-menu
- CHANNEL: next / previous chapter
- CHANNEL long: next / previous track
- NOSE: Go to the next chapter
- Long BOUQUET: Go to the next track.
- AUDIO: audio track menu
- Long AUDIO: Audio menu of the DVD
- RADIO: Switch audio track
- RADIO long: DVD-Audio menu
- TEXT: toggle subtitles on /.
- VIDEO (PVR) next perspective
Movie Preview Plugin List
There the plugin Movie List Preview an extra on EMC customized version of the Coolman & zombi - can be found -> HERE <<.
With this you can create thumbnails for the pictures.
Values ​​for the film list (list box) in the <widget name = "list":
(Some settings are only used if the Setup "movie list is skinable" is turned on)
(Skin templates are in / usr/lib/enigma2/python/Plugins/Extensions/EnhancedMovieCenter/CoolSkin /)
cool font = "Regular, 20" and font size of the movie list
cool selectfont = "Regular, 20" and font size of the marker points [video] key
(Thus,  with a broad list of font for the film took a small font for the mark  so the mark does not fail to be wider than the icon. Most fonts can be  used but the same as in cool font =.)
cool folder size = "500" width directory names
CoolMoviePos = "95" position movie name
cool movie size = "450" ​​width movie name
Date cool font = "Regular, 20" font and size for dates
CoolDatePos = "495": positons Date
cool date width = "110" width Date
CoolBarPos = "30" position of progressbar
CoolBarHPos = "8": Progressbar height position
CoolBarSize = "55.10": Width and height of progressbar
CoolBarSizeSa  = "110.16" width and height of progressbar in the setup if "movie list  is skinable" ("listbox is skin able") is set to YES.
CoolProgressPos = "1000": position of the progress indicator in%
(Sol only display the progress bar or% are shown, simply push the unnecessary display outside the visible range.)
cool title color = "0", "0" = it the Filmitel in the same color as the status, "1" = always in white.
Date cool color = "1", "1" = the date that is in the same color as the state title when cool color = "1". "0" = also available in white color when cool title = "1"
cool  highlight color = "1", "1" = is so that only the selected entry in the  same color as the status when cool color title = "1".
default color = "# FFFFFF" color for progressbar when colors are disabled in the setup (0% and 100)
UnwatchedColor = "# FFFFFF" color for progressbar "status unseen"
watching color = "# 3486F4": color for progressbar 'status alluded "
FinishedColor = "# 46D93A" color for progressbar "status seen Done"
recording color = "# 9F1313" color for progressbar "during shooting or cutting operation with moviecut plugin"
BackColorSel = "# 000000": Background color for the cursor
EMC setup screen:
Total  default setup screen is to find an info file in the plugin in /  usr/lib/enigma2/python/Plugins/Extensions/EnhancedMovieCenter/CoolSkin  /.
Converter for "EMCMediaCenter" (movie player Skin)
If EMCClockToText = used for the representation of the film length and the date, time
EMCEventName = Makes the film META information in form
EMCServicePosition = Represents the Cutlist marker for non-TS movies
EMCServiceTime = Calculated length of the film, if possible, not for TS movies
  • enigma2-plugin-extensions-enhancedmoviecenter_3.0.0_all.ipk
bogdanm
Moderator
Work good in my box.
I think is faster from last version and i think audio work beter on this version
Tamaki
Google translated:
feature list
    Thus appears on the status of "Not Seen" or "Done seen" no query whether more should be continued to the last position. Can while still enjoying the "<" and ">" **** to get the last position as a marker was placed here.
  • The [Bouquet] **** to scroll to the top or bottom of the list. With the [cursor left / right] side manner.
  • Automatic Trash:
**** from EMC and its function:
- CONTROL CROSS: navigation list in the film (<and> **** scroll entire pages)
- MENU: DVD-menu
EMC setup screen:
I can confirm, it is working fine.
Can you attach also Movie Preview Plugin List, as i cannot find it?
rassi
Where to put it?
If i put it in enhancedmoviecenter dir it doesn't start anymore.
Dou you know?
Plugin.py can be for older 2.02 EMC, maybe info in first post is incorrect and it is some left over from earlier release. I have never tested thisplugin.py for 3.0 or older release.
kitsuneyo
Weirdly, this is now making my box crash every time I try to play a video. When I use the regular media player it works.
Crash log is attached.
Any ideas anybody?
  • enigma2_crash_1322094081.log.txt
Tamaki
Any ideas anybody?
With this plug i have crashes only if i press twice ok botton.
Did you do this?
kitsuneyo
I'm not sure, I don't think so. It worked fine for a day, then it would crash the box every time I tried to play a video.
kitsuneyo
I stopped using it now. I don't know what went wrong but I couldn't stop it from crashing. Shame as it's a good add-on.
Tamaki
That is strange.
I use it both on duo and uno without problems.
MAybe it conflicts with some other plug you have installed or you have ram problem?
a911
The BH Lover
That is strange.
Am not using EMC,,,,but I am interested in " you have ram problem"
How to solve this issue,,,,:confused:!
RgdZ
a911
