Hello,
I have one minor and one fatal problem with the EMC. They might relate to same issue. I bought my Duo2 (using openATV 5.1) some two weeks ago and I just can't figure these out - so hopefully you could help me.
First the minor one - when I go to EMC settings and I suppose to get some additional information for each setting line, I just get the name of the Help string i.e. HELP_About or HELP_Disable EMS (tried to link a picture here, but were not allowed to do so)
The fatal error relates to info as well. When in EMC (or watching a recording) I press the HELP button on a remote, the box hangs and does not react to any other remote command but vol+/- and mute (box indicates reading the commands though by flashing a mark in lcd panel). Even from WebIF, the commands restart GUI or device do not work. The power button in front of device does not react (the back panel switch works of course). Only thing that works is ssh terminal connection and the command "reboot".
I have reinstalled the image several times, even restored the factory settings and removed the emc and all the settings from /etc/enigma2 dir (files containing text EMC) and all the EMC related fromn the file "settings". Tried with the deafult skin, MyMetrix both in SD and HD mode, but nothing makes any diffrence.
The system debug log shows that there is an exception in a module MovieSelection.py ('list index out of range')
Here is a part of a debug log (system using default skin)
[LOG]
00:13:07.292 [ ] driver/rcinput.cpp:23 handleCode 1 8a 1
00:13:07.294 { } Screens/InfoBarGenerics.py:204 actionA KEY: 358 0 KEY_INFO INFO
00:13:07.523 [ ] driver/rcinput.cpp:23 handleCode 0 8a 1
00:13:07.525 { } Screens/InfoBarGenerics.py:204 actionA KEY: 358 1 KEY_INFO INFO
00:13:07.526 { } Components/ActionMap.py:46 action action -> PluginMovieSelectionActions EMCINFO
00:13:07.547 { } skin.py:1034 readSkin [SKIN] processing screen EventViewSimple:
00:13:07.563 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element key_blue in <class 'Plugins.Extensions.EnhancedMovieCenter.MovieSelection.IMDbEventViewSimple'>
00:13:07.568 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element epg_description in <class 'Plugins.Extensions.EnhancedMovieCenter.MovieSelection.IMDbEventViewSimple'>
00:13:07.570 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element channel in <class 'Plugins.Extensions.EnhancedMovieCenter.MovieSelection.IMDbEventViewSimple'>
00:13:07.599 { E } Plugins/Extensions/EnhancedMovieCenter/MovieSelection.py:1529 showEventInformation ('[EMC] showEventInformation exception failure: ', 'list index out of range')
00:13:08.138 [ ] gui/esubtitle.cpp:122 setPage setPage
00:13:09.138 [ ] gui/esubtitle.cpp:122 setPage setPage
00:13:09.138 [ ] gui/esubtitle.cpp:143 setPage add 119 454 506 44
00:13:09.138 [ ] gui/esubtitle.cpp:144 setPage disp width 720, disp height 576
00:13:09.138 [ ] gui/esubtitle.cpp:143 setPage add 119 498 506 48
00:13:12.455 [ ] driver/rcinput.cpp:23 handleCode 1 8a 1
00:13:12.456 { } Screens/InfoBarGenerics.py:204 actionA KEY: 358 0 KEY_INFO INFO
00:13:12.687 [ ] driver/rcinput.cpp:23 handleCode 0 8a 1
00:13:12.688 { } Screens/InfoBarGenerics.py:204 actionA KEY: 358 1 KEY_INFO INFO
00:13:12.689 { } Screens/Screen.py:150 show [SCREENNAME] UnhandledKey
00:13:14.570 [ ] gui/esubtitle.cpp:122 setPage setPage
00:13:14.695 [ ] gui/esubtitle.cpp:122 setPage setPage
00:13:14.696 [ ] gui/esubtitle.cpp:143 setPage add 119 454 188 44
00:13:14.696 [ ] gui/esubtitle.cpp:144 setPage disp width 720, disp height 576
00:13:14.696 [ ] gui/esubtitle.cpp:143 setPage add 119 498 514 48
00:13:16.484 [ ] driver/rcinput.cpp:23 handleCode 1 8b 1
00:13:16.485 { } Screens/InfoBarGenerics.py:204 actionA KEY: 139 0 KEY_MENU MENU
00:13:16.714 [ ] driver/rcinput.cpp:23 handleCode 0 8b 1
00:13:16.716 { } Screens/InfoBarGenerics.py:204 actionA KEY: 139 1 KEY_MENU MENU
00:13:16.717 { } Screens/Screen.py:150 show [SCREENNAME] UnhandledKey
00:13:18.161 [ ] gui/esubtitle.cpp:122 setPage setPage
00:13:18.287 [ ] gui/esubtitle.cpp:122 setPage setPage
00:13:18.287 [ ] gui/esubtitle.cpp:143 setPage add 119 454 228 44
00:13:18.288 [ ] gui/esubtitle.cpp:144 setPage disp width 720, disp height 576
00:13:18.288 [ ] gui/esubtitle.cpp:143 setPage add 119 498 536 48
[/LOG]
Is there a mandatory plugin related to EMC that I might have missed? Or any other module?
Any kind of help is appreciated - I'm getting a bit desperate...
[LOG]
[/LOG]
