Enhanced Movie Center Upgrade
Moderator
Its from 201608 and now they updated the eit file that support multi epg
From the github
As i soon as i get home from work i will repack and test the lastest version from git, and will turn it here public regarding Black Hole 3.0.2 Images.
There´s no need to repack it for OpenBH 06 because it has its own version.
Note: The lastest version is git20160821, althoutgh when repacking it from git, i will repack with lastest commited changes, afaik ... atm 20161103. In this case i will change the git version as git 20161103 ( raised version ).
Moderator
  • enigma2-plugin-extensions-enhancedmoviecenter_4.0.+git1315+7a3214c-r12_all.ipk
Seth_72
do you know when i start emc in obh and press epg data , that emc dissaper and cant press any button on remote, need to reboot box to work again.
Regards Seth
Moderator
Regards Seth
No, i haven´t tested it regarding OpenBH 06. I only tested just a little bit on Black Hole 3.0.2.I:
  1. Installation OK
  2. Execution OK
  3. PlayBack OK
  4. Download Covers and Movie Information OK.
ch061441
How to get it installed on BH 3.0.2.J?
Not found updates for EMC...
And over download i only see the old versions.
Regards.
Manuel
Gesendet von meinem SM-G935F mit Tapatalk
Seth_72
does anyone know how to lock the epg button in enhanced Movie center so its dont work when using obh . if installed and open emc ,mark a move and press epg button on remote, emc dissapear and no button in emc works.
