Enigma Duplicates
shax
Vip
Simple open source tool for removal of duplicated and unneeded services from Enigma settings.
Who does it do?
Cleans your settings from services you don’t want/need
Why should I use it?
All satellite receivers have limited memory and CPU resources.
By removing unneeded services from settings you’re making your receiver faster,
your settings better organized and easier to maintain.
How does it work?
It will only list services with same name on same transponder and satellite.
Then it’s up to you to decide what services will be deleted based on the info
about every service (in what Bouquets is it used, PIDs it has, provider…)
What’s the best way to use it?
If you’re not making settings to be used by other people than yourself
easiest way is to first go with “Remove unused” which will remove ALL
services not used in any Bouquets and then proceed with other methods.
This will greatly decrease number of services (and duplicates) in your settings.
Other method is to select (automatically) duplicates not used in any bouquets,
and than remove selected services.
Or you can manually go trough each service and select if it should be removed or not,
it’s all up to you.
DIRECT DOWNLOAD
HERE
Source code on GitHub:https://github.com/shaxxx/EnigmaDuplicates
