Enigma Signal Meter - Krkadoni Edition
shax
Vip
First release of Enigma Signal Meter was quite popular, but it was buggy, lacked support for many different Enigma 1 and Enigma 2 flavors, had no support for multitasking, had confusing and different interface for E1 & E2 receivers. That's why new Enigma Signal Meter - Krkadoni Edition was born.
Description:
Fast, small, portable, simple and free application for Enigma 1 / Enigma 2 satellite receivers, build to help you align you satellite dish to perfection.
Features:
  • SUPPORTS ALL currently existing Enigma1 and Enigma2 receivers and images
  • same simple interface used for Enigma1 and Enigma2 boxes (originally they are quite different)
  • full background processing (running tasks will not hang application)
  • small & portable (doesn't require installation and can be run from USB stick)
  • autoupdate (offers to update when new version is available)
  • voice reading of signal levels (uses default Windows voice)
  • signal beeping (beeps signal with frequency depending on signal level)
  • works remotely (just forward web port and you can connect from anywhere
Requirements
  • Enigma 1 or Enigma 2 based satellite receivers with running Web interface (WebIf)
  • Network connection between receiver and computer
  • Windows XP or higher
  • .NET Framework 3.5
  • 1 MB of free disk space
So far tested and working on:
- DM500
- DM500HD
- DM600
- DM7000
- DM7020
- DM7025
- DM800
- DM800SE
- DM8000
- VU+ Uno
- VU+ Duo
- AzBox Premium
- AzBox HD Elite
- AzBox Ultra HD
- Kathrein UFS 910
- IPBox 9000
- Amiko Alien
- Topfield TF 7700HD PVR
- Gigablue solo
- ClarkeTech ET9000
For best results when searching (faster response time):
- don't search while zapped on HD channels
- don't search while recording
- don't search while receiver's web interface is open in web browser
- don't search if you have other plugins running
- generally avoid anything that slows down your receiver
Thanks to all people on Satelitski Forum who tested.
No external links. Upload file and images into this thread :)
To refresh this topic.
I give attribute fantastic Program.
Today first time i have use this fantastic program in practice tuning my antenna for max gain, from my old friend Munja @shax .
I used the windows version on laptop Windows 8.1.
Best of all is that this program has the option of speaking signal strength .
Which in practice means that you have your hands free and eyes to adjust antenna.
Requirements
If you do not have installed .NET Framework 3.5 you can use windows update to install
I have use offline instalation with program in my zip.
For this you need a Windows installation disk / CD / USB.
Do not forget OpenWebif plugin in the box must be enabled.
To be sure start a program with administrator rights.
You must enter under Profiles BOX IP , loogin and pass.
With the mute button in the program you can include signal strength speech.
there is an app for mobile phones I have not tested.That was already in the forum.
Last news and all programs here
http://www.krkadoni.com
The result of fine tuning from NW EU with this nice program.
antenna 78 cm Triax with Solo 4K
