enigma2 not detected
Dear bro thanks for ur prompt reply. Actually let me give u my setup first i am using vu + duo2 and having a Single monblock LNB which should be receiving two sat like 95E and 100 E. even without diseqc as the single monblock lnb has one outlet wire i am unable to configure both the satellite.
Using a monoblock can cause problems.
First is it a 6 degree monoblock, or other?
What size dish, are you using?
Try setting the tuner, that has the monoblock, to simple, Diseqc A/B, select the satellites, and try a manual scan.
Have you checked the monoblock is working, and aligned correctly?
It is issued by dish tv india. This lnb has only one terminal to connect with the tuner. Mono block is working perfectly fine. My vu+ duo2 has only one dual tuner.i want to use only one terminal of tuner with mono block lnb.please let me know how to configure tuner for this setup
Dish size is 65 cm
Try going into the menu, and setting the Tuner up to simple, Diseqc A/B, and set the satellites up.
Is that a picture of your dish, as it's currently set up, or just an example?
Dish is already setup for nss 6 and ses8 I managed to get all channels with other receiver
Checking lyngsat, both NSS 6, and SES 8, are listed on the same satellite, 95E, which doesn't require a monoblock LNB.
If these channels are working, on your old receiver, then the dish, LNB, and cabling, are working and the problem must be the Tuner setup.
Try using Simple, Mode = Single, Satellite 95E, and scanning in the channels.
Which Tuner, LNB input, have you got the cable going into? The top, Tuner A, or bottom, Tuner B?
Sorry my mistake. I'm getting signals from nss 6, ses8 and asisat 4b
Both satellite is working on previous recaiver.my vu+ duo2 has dual tuner
Lnb cable is going to bottom tuner input
If you like to receive only 95.0E NSS 6 & SES 8 satellite connect antenna to tuner A ( the top Tuner )
Main Menu >>Setup>>> service searching>>Tuner configuration
In tuner Configuration Tuner A ( top Tuner )
configuration Simple
Mode Single
Satellite 95.0E NSS 6 & SES 8
No Diseqc
Configuration Tuner B (bottom Tuner)
Configuration mode >>> Loop through to
Connected to Tuner A
Connect antenna to Tuner A (topTuner)
Scan
If you have no scaned channels no signal
you can use Sat finder and Positioner setup to test antenna
Mode Single
No Diseqc
Scan
I want to receive nss6, ses8 and asisat 4b with mono block lnb
Please see monoblock lnb has only one cable connection
Im not sure about your monoblock positions and possibilities.
which satellite is first and which second satellite on your monoblock.
But OK
You use tuner A (top tuner)
connect antenna cable to top Tuner A
Configuration mode Simple
Mode DiSEqC A/B
Port A ( select first satellite from your monoblock)
Port B (select second satellite from your monoblock)
But OK
Mode DiSEqC A/B
Do I have to configure tuner b even though it is not connected to any cable.
You do not have to configure
but if it is configured is used for the recording / transcoding / using PIP
Tuner B is within the receiver connected to the signal from the antenna on Tuner A
Turner "A"
Configuration mode : Simple
Mode : DiSEqC : A/B
Port A : nss6 and ses8 95 E
Port B : intelsat 4b 100.5 E
Set voltage 22KHz : Yes
Send DiSEqC only on satellite change : Yes I configure as above is that correct?
Turner "A"
Mode : DiSEqC : A/B
I believe that is good.
Provided that the position is good.
I do not know how it is in Asia.
if not try the other way around
Port A : intelsat 4b 100.5 E
Port B : nss6 and ses8 95 E
Thank you very much
I greatly appreciate your help
Once again thank you
