Enigma2 Structure
Tamaki
I would like to create a setting editor
Where can I find the structure of the enigma2 settings?
You can download a pack made by Vhannibal or other settings (use Google).
Then put satellites.xml in /etc/tuxbox
all other files in /etc/enigma2
I hope this is what you need.
Good work.
Dogstrike
Good work.
Thanks for the reply
But I would like to create a new program for managing the setting
enigma2 ... (Vb.net)
Then I need the structure of the various files ..
Tamaki
I think you should open every single file and see what's in there.
I'm not sure, but i don't think there is anything around with it.
But maybe, some guys that prepares settings can help you.
Let's wait and see, if anyone knows. :)
