Request Enigma2 WebInterface Transcoding API?
GedFrensik
Hi there.
Using VU+Duo2 hardware with VIX in it.
The device has dualCore CPU, hence transcoding can be triggered from WebIf directly.
Transcoding Settings are under WebIf aswell, under Settings.
Question and Request.
May it be so that Transcoding parameters (bitrate, resolution, fps e.g.) could be delieved via POST/GET invoke during the transcode trigger itself.
e.g. Like this:
http://boxip/transcode?ref=channelRef&resox=640&resoY=360&bitrare=512&fps=25
Result would be the same as now at port 8002.. m3u file contaiing the stream url etc..
Ok, Thanx.
Here, but what this have with OpenPLI.
http://openpli.org/forums/topic/20164-openwebif-e2openplugins/page-56#entry388984
Ok, Thanx.
No this is the Open Web interface project started by Black Hole coder inside E2 open plugins that is a cross images plugins platform. The Pli board or here makes no difference.
