Enigma2
petine
Dear friends,
I think I made a mistake recently by removing he Enigma2. However I am not sure about that.
The message I receive when opening a channel like BBC One on FilmOn in IPTV is according the sceenshot attached.
Hope some one can help me.
I don't have a folder called 'ServiceApp' under 'SystemPlugins'.
I'd suggest you delete that folder, restart, and then reinstall whatever plugin it was, to watch IPTV.
But that is just a humble suggestion, don't blame me if something goes wrong. :)
Why would you delete the Enigma2 folder?
If using Open Blackhole install teh Backup, if you have one, or load the image again, and if asked to use a backup choose yes.
Dear friends,
On your RCU press:
1) MENU
2) Drop down on the list and enter <plugins> browser by pressing <OK>
3) Press the <GREEN> button
4) Drop down on the list and enter <system plugins> by pressing <OK>
5) Drop down on the list and install:
serviceapp
On your RCU press:
1) MENU
serviceapp
Unfortunately the "serviceapp" is not mentioned in the system plugins.
Actually I now notice that Gold_66 mentioned the same for BH while I am working with OPENBH.
So I am still waiting for more suggestions.
If not list is installed!
Run the following commands by using telnet: ( one at once )
opkg remove enigma2-plugin-systemplugins-serviceapp
killall -9 enigma2
If these commands don´t remove nothing, though serviceapp is not installed, install it:
opkg install enigma2-plugin-systemplugins-serviceapp
killall -9 enigma2
And retry playing the service that gives the issues.
OK @nunigaia,
Thanks again for your reply, but it looks like I have to apply a terminal within OBH and that I am Not (yet) used to.
With UBUNTU yes but with OBH not yet.
Can you explain how it works?
Kind regards.
OK @nunigaia,
Kind regards.
You must install an FTP tool and Putty in your PC, in order you be able to use command line.
I use winscp and putty.
You can download it from:
1) for WINSCP
https://winscp.net/eng/download.php
2) for PUTTY
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
Or as you are newbie ;)
FTP tool and command line --> Dreambox Control Center
§ --> link --> http://www.vuplus-community.net/board/threads/new-dcc-e2-1-42.3427/#post-159621
