EnigmEdit V 1.3.8
a911
The BH Lover
EnigmEdit V 1.3.8​
HISTORY VERSION Version 1.3.8 Added Reload Method (html/tenet) in profiles so that every receiver can be managed as you like Separator char for exported text file can be set in option windows Added number on exported text file Changed management of profiles Now alert windows in show even if splash screen is off Fixed a bug on sending an emty Terrestrial.xml file Fixed a bug on numbering Radio Bouquet Fixed a bug on profile Minor fixes.​
enjoy!​
Thank you so much for your help. I just have to take Italian lessons. I should be ready to read and understand the guide by end of 2015 !
Si fratello Paolino, e grazie mille. I'm working on it. and I'm grateful for the guide.
Ciao bello !
p.s: I hope you're impressed with my progress. Capice? hehehehe...
